E-Brake (need help fast)
Old May 12, 2010 | 09:42 PM
souldier08's Avatar
hey fellas so i was wondering if any of you knew how to tighten the e-brake because it feels kind of loose and and i'd have to pull it all the way up so it wont roll... any help guys?
Old May 12, 2010 | 10:26 PM
souldier08's Avatar
bump
Old May 13, 2010 | 06:00 AM
twista's Avatar
First and easiest is adjusting it at the back of the ebrake handle. open the lid on the center console find two screws in the bottom remove them. pull the ebrake on and the console should lift out pop out the intercooler spray switch. i think its an 8mm nut on the back of the ebrake handle tighten a few turns at a time(ignore the funny metal clip that stops the nut from coming loose) and then test.
Note there is only so much adjustment available from this location, if you use up all the thread here then you have to tighten the cable through a hole in each rear hub
Old May 13, 2010 | 07:36 AM
DraheimEvo8's Avatar
+1
Old May 13, 2010 | 02:23 PM
souldier08's Avatar
i have at 05 evo so would everything be the same?
Old May 13, 2010 | 02:34 PM
fugiwara's Avatar
https://www.evolutionm.net/forums/ev...-question.html
Old May 13, 2010 | 04:45 PM
souldier08's Avatar
daym that lievo.com thing is freaking sweet thanks bro
Old May 14, 2010 | 03:34 AM
twista's Avatar
evo 7-9 are all the same
