banging noise when shifting hard
If the drivetrain shock is bottoming out the bushings, then the diff shock is lessened initially, then all of the shock is instantly transferred to the diff when the bushings go flat. This would still be worse than transferring more shock to the diff gradually and in a linear fashion with stiffer bushings.
I've got a full set of Energy bushings waiting to be installed. Just got to get around to it.
its called your letting the clutch out to fast and that sounds is the sudden load of the drivetrain being transfered to your rear diff gears..... its a great way to kill your rear diff.
learn to drive better and the sounds wont be there. you cant just pop the clutch out super quick when you shift
Check your facts next time before you try to be so condescending.
I have both the Beatrush rear differential mount bushings and propellar shaft bushings. I do notice some noise after the installation, especially from the rear of the car. The car does feel more solid and the thump was eliminated also. I'll just add the noise to the number of other noises that my Evo has.
It appears changing the diff side mounts isn't too difficult. Would just changing those bushing be good enough? I'm all stock now and don't know if I want the trouble and potential added noise of swapping the mustache bar bushings.
