banging noise when shifting hard
Old Jul 26, 2010 | 03:40 PM
turboback1243's Avatar
When i shift fast from 2-3 or sometimes 1-2 i hear a bang noise which sounds like its coming from my rear diff. I can hear it coming from under the rear seat...this doesnt happen everytime i shift hard either only sometimes. What mount(s) should I check? any ideas
Old Jul 26, 2010 | 04:07 PM
EvoJoeIX's Avatar
its called your letting the clutch out to fast and that sounds is the sudden load of the drivetrain being transfered to your rear diff gears..... its a great way to kill your rear diff.
learn to drive better and the sounds wont be there. you cant just pop the clutch out super quick when you shift
Old Jul 26, 2010 | 04:11 PM
Trojan man's Avatar
like they said it's "normal" for an evo, but i don't think it's from bad driving so much as weak rear bushings. I can slam gears in plenty of cars and not get that noise, but the evo takes a little more finesse. You'll get a feel for it don't worry.
Old Jul 26, 2010 | 04:13 PM
EvoJoeIX's Avatar
i wouldnt call that sound normal, unless you dont have a problem having your diff rebuilt
i can guarantee this sound is not from the bushings on the rear diff
Old Jul 26, 2010 | 04:18 PM
turbolagdsm's Avatar
I was gonna say , this is a common noise though isn't it, Ive heard it in mine plus another evo as well.
Old Jul 26, 2010 | 04:22 PM
meckert's Avatar
Normal as in Every Evo has the same problem..yes, change the diff bushings, and mustache bushings and the prob will go away--they are too soft and flex under hard shifting causing the banging noise---BTW there are a ton of threads on this
Old Jul 26, 2010 | 04:24 PM
Smike's Avatar
Rear diff bushings. Upgraded poly bushing help with the rear thump.
Old Jul 26, 2010 | 04:28 PM
darkside4G63's Avatar
incorrect. you have no idea how many miles are on his car, there for you dont know how worn his diff/ mustache bar bushings are. ive got 104k on my 8 and i makes that sound fairly easily. can shifting hard make the clunking noise from the rear diff, sure. does that mean that the noise is due to his inablitity to drive, no. you can go to many sites (i.e. Buschur, AMS etc...) that sell solid rear diff mounting solutions as well as replacement urethane inserts to replace the soft factory mounts. not only do they claim that they aid in better 60' times but they get rid of the annoying clunk from the rear diff during hard shifts. more people on this forum need to spend more time helping folks out and less time trying to jump someone at any given opportunity. sorry for the rant but if you can help someone, do it, if not the shut the F up....... hope that helps bro
Old Jul 26, 2010 | 04:29 PM
i got ninja'd. i type slow, LOL
Old Jul 26, 2010 | 04:54 PM
EvoJoeIX's Avatar
i dont care if the car has 10 miles on it, if your shifting hard and letting the clutch out fast you will get that noise in the rear diff. that noise is not good for the diff at all
yes the aftermarket bushings might help out, but its not gonna get rid of that noise when you pop the clutch out from fast shifting.
Old Jul 26, 2010 | 05:41 PM
EvoTio's Avatar
Great Advice. Replacing the rear bushings eliminated my rear thump on hard shifts completely.
Old Jul 26, 2010 | 05:48 PM
Davo's Avatar
the simplest and cheapest way to cut back this noise is the beatrush kit
then we have the energy suspension kits and then the mustache delete bar which sheds pounds also
Old Jul 26, 2010 | 07:17 PM
jy951's Avatar
I would think the soft diff bushings would actually help the diff not take shock of fast clutch release.
Old Jul 26, 2010 | 07:23 PM
AMSevo8man's Avatar
just like everyone else said. replace those rear diff bushings and you should be all good. But you still should probably take it easy, and learn how to speed shift without slamming gears.
Old Jul 26, 2010 | 11:36 PM
Thanks darkside and everyone who didnt jump to conclusion and suspect i drive like a 7 year old thats what my buddy was saying too ill look into it and if i need driving school which i dont evojoe you are first on my list
