Slipping clutch or other issues?
Old Nov 10, 2010 | 08:24 AM
BoostAddict85's Avatar
Exclamation Slipping clutch or other issues?
So when in 3rd-5th gears, especially on the highway when I accelerate rather quickly, My rpm's rev up real hard then drop down a little then it starts actually going fast. I did not have this problem before I got 3" TBE, Perrin intercooler, upper & lower IC piping, o2 housing. My tuner thinks its my clutch beginning to slip/go out. Is this the case or could it possibly be something else? I have NO money for a clutch/install at the moment so I am really worried. This also happens on the street if I want to show off the ride. Usually in 3rd gear, I floor it (well not all the way) but again, my rpm's rev up real steep for a split second until it goes back down and hooks up like a rocket. I don't want to ruin anything so I have started to baby it. Any pointers from any experienced tuners or anyone who has dealt with this would be great. Thanks a lot.
Old Nov 10, 2010 | 08:26 AM
Oh, it is the stock clutch and the car has 28k miles on it btw
Old Nov 10, 2010 | 08:28 AM
So when in 3rd-5th gears, especially on the highway when I accelerate rather quickly, My rpm's rev up real hard then drop down a little then it starts actually going fast. I did not have this problem before I got 3" TBE, Perrin intercooler, upper & lower IC piping, o2 housing. My tuner thinks its my clutch beginning to slip/go out. Is this the case or could it possibly be something else? I have NO money for a clutch/install at the moment so I am really worried. This also happens on the street if I want to show off the ride. Usually in 3rd gear, I floor it (well not all the way) but again, my rpm's rev up real steep for a split second until it goes back down and hooks up like a rocket. I don't want to ruin anything so I have started to baby it. Any pointers from any experienced tuners or anyone who has dealt with this would be great. The car has only 27k miles on it and it's the stock clutch Thanks a lot.
Old Nov 10, 2010 | 08:30 AM
Old Nov 10, 2010 | 08:32 AM
Jrah2987's Avatar
Veteran: Air Force
Starting happening to me a while ago. The best clutch test I did was put it in 5th around 40mph and floor it. The clutch slipped a bunch, which told me the bad news.
Edit - FYI 2 weeks after I did that, 3rd gear starting grinding. About 3 weeks after that, 2nd gear was notchy. 15 minutes after that, I turned it in for a new clutch/flywheel and a Bushwacker. Good luck man.
Old Nov 10, 2010 | 08:34 AM
03evo8gsr's Avatar
wut kind of clutch you have in her? how many miles?and r u tunned?
evolution2186's Avatar
With your addition of the above mod's, you've reached the end for the stock clutch. When the rpm's shoot up it means your clutch isn't holding. The more you make it slip, the faster it will go out.
Old Nov 10, 2010 | 08:35 AM
It mentioned stock clutch, 27k miles.
Old Nov 10, 2010 | 08:46 AM
03evo8gsr's Avatar
sounds like its going out. also r u tunned with those mods?
Old Nov 10, 2010 | 08:47 AM
crazybaldhead's Avatar
It is definitely your clutch!
Old Nov 10, 2010 | 08:55 AM
Jrah2987's Avatar
Veteran: Air Force
Am I hallucinating or did you post this twice? Your other post has the same answers.
Old Nov 10, 2010 | 09:07 AM
ghammer2's Avatar
Unfortunately it does sound like your clutch is slipping. You can baby it around and try to save for another clutch. You should be good for a month or two.. Just don't do anymore showing off or you'll be replacing it much sooner..
Old Nov 10, 2010 | 09:21 AM
vietman's Avatar
Yeah its your clutch and like mentioned above baby it so you can save money for a clutch this is when people driving around you are going to get mad especially if you drive up hill Lol
Old Nov 10, 2010 | 09:24 AM
03evo8gsr's Avatar
ya he did post twice
Old Nov 10, 2010 | 09:47 AM
Earthen's Avatar
Definately sounds like the clutch, although when mine was wearing out it slipped in the lower gears first.
