My evo when I drop 3rd gear nuturalizes
When I drop into 3rd it nuturalizes and some times on 4th...
I then shift back to 5th gear or 2nd gear and its normal some times.
This is so weird and complex.
3rd gear use to grind! and 4th is hard to put into some times
3rd only grinds
a shop did the liquid change for me.
However I was told the gear is fine because it never pops out of gear. (only 3rd grinds though)
I ordered
3-4 FORK
3-4 Synchro
3-4 Slider
Hopefully this fixes the problem
synchros are so cheap if i was you i would replace them all while i'm in there or soon you might be at it again. Before your fluid change did you have this problem? I would either use amsoil or oem diaqueen in the tranny.
3rd was grinding and the issue also is im using an act clutch!
I am going to change them all as you advised me because it was fairly cheap i only spent 140 bucks.
pb91
Jun 8, 2011 02:44 PM
Clipse3GT
Mitsubishi TC-SST Discussion
Jun 15, 2010 09:33 AM
