Need advice for engine Rebuild
Old Dec 10, 2010 | 09:50 AM
murlo26's Avatar
Right but you didn't have a failure.
So that basically puts him above $6000 for all new oiling system and install on that because even if he doesn't need a new block whatever failure he had will results in small chips etc in the oil system.
This is assuming his head/turbo are fine as well.
Its really all just speculation until he knows the extent of his damage.
Old Dec 10, 2010 | 10:01 AM
mlomker's Avatar
Originally Posted by chkmgnt59
Per cobb plano
Look like a good deal. That quote didn't mention any head work. When a piston chunks you're at least looking at some welding, perhaps new valves, etc. If pieces went out through the turbo then that could be damaged.
I haven't seen a build yet that didn't have a surprise and end up going over the first estimate.
Old Dec 10, 2010 | 10:57 AM
chkmgnt59's Avatar
^^ cams already installed, and my engine is still pristine. I was just pointing out that 5500 will do it if the engine isn't ruined. I agree that w/ damage, 10k is a better guess.
Old Dec 13, 2010 | 09:15 AM
ChrisCarey's Avatar
Originally Posted by MR_Edition
Hi there guys,
this my first thread , in the last couple years I used to read only but now it is time came to ask Qs and take experiances from you guys what I call them (Experts)
the Sad Story
My Evo X engine is almost dead cuz of overheatin, i was running 1.8 bar racing with a lamborghini Gallardo that night and after done with race my freind in the back saying that a heavy white smoke is coming out from the cat-backs. so i took the car to the garage today and dicovered that the forth piston is lack of pressure. the engine will be opened for the first time, so i will change the pistons and the connecting rods only, and leave the stock crank as it is.
so i need a good spec from you guy to start this project to deliver a 500-550 WHP range. My current setup is :
HKS Hi-Power Exaust system
Custom intake system
Tuned (POS)
and the rest are tottaly stock
MY budget is around $5500
so what are your recommendations guys ??
thank you ,
Ahmed
We would love the opportunity to help you out with some recommendations sir We work with several clients in Dubai and all over the world.
stayer
10
May 23, 2017 09:38 PM
iceman23007
Feb 3, 2013 06:00 PM
nubi4life
Apr 12, 2008 07:26 AM
