Newbie here, question about knocking during turn
Hey Guys,
I've owned my Evo about 2 months. It's a 2006 MR. I've noticed that during slow turns I can hear/feel a click or knock coming from what feels like the front left tire. Any ideas on what it might be? Any help would be appreciated, thanks.
I had the same exact issue, knocking noise / clicking during left turns (common problem with Evos that have a good amount of miles on them). The solution to your problem is in the strut / strut mount. You must replace the left front strut and mount. It sounds like an axle issue because its usually only when your turning to one specific side.
same issue here i hear it coming only from the driver side every time i turn right.
here are two threads i found with the same or similar issue.
https://www.evolutionm.net/forums/ev...ill-there.html
https://www.evolutionm.net/forums/ev...ront-left.html
i lifted the left side up and checked for any wheel wobble by using the 12 and 6 o'clock method and the wheel didnt move at all. then i took the wheel off and the this is what it looked like.
i checked to see if there was any rubbing on the plastic but no signs of rubbing. i then checked the axle it looks to be all in one piece, no cracks or bends. i then checked the boot for any leaks or tears and all is fine.
any ideas??
any ideas??
Do you know how much they normally run?
