Best way to clean and oil pan...
Old Sep 27, 2011 | 04:51 PM
turborocky's Avatar
Well within 3 months of buyin my evo 8 i ran into my first set of problems. Rocker arm on one of my exhaust valves apparently was jus laying in the head untill somehow it got jamed and shot it through the valve cover. So today i droped the oil pan to clear the shards and i was wondering wats the best way to clean the pan? My pops said using gasoline does the trick and i know other people have used break clean. Any suggestions...
Old Sep 27, 2011 | 04:57 PM
binky's Avatar
Were there metal shavings in the oil pan?
-Bink
Old Sep 27, 2011 | 05:30 PM
FedEvo8's Avatar
Gasoline would work just fine. Engine degreaser, brake cleaner or carb cleaner would also work.
Old Sep 28, 2011 | 09:45 AM
turborocky's Avatar
ya there were shavings and rocker bearings since it cracked and broke itself. Plus there were pieces from the valve cover also as it created a hole in it. Luckily the head wasnt damaged... Thanks for your opinon
Old Sep 28, 2011 | 10:01 AM
Ev0ikon's Avatar
You may want to replace your oil cooler also.
Old Sep 28, 2011 | 10:05 AM
Kracka's Avatar
Replace the pan and cooler.
Old Sep 28, 2011 | 10:20 AM
veloracer's Avatar
I've used this product with great results
Super Clean
Old Sep 28, 2011 | 10:49 AM
binky's Avatar
Reason I asked if there were shavings in the pan is because that means your oil and oil cooler are contaminated. You need to replace your oil cooler because you will never get all the shavings out and the shavings WILL kill your bearings in the motor.
To be safe, I would put the new oil cooler and new oil / oil filter in, then run the oil for 25-50 miles then change the oil and filter again to make sure most of the shavings are out.
-Bink
evo1008
Apr 13, 2016 07:05 AM
Ralli_Red
13
Aug 20, 2015 07:57 PM
EvoAlex48
32
Jan 4, 2015 10:01 AM
turbotaloon95
May 30, 2012 06:04 AM
tscompusa2
Nov 12, 2011 02:57 AM
