Front bumper problems?
Old Dec 27, 2011 | 07:19 PM
EvoVIII_03's Avatar
How goes it people? I have problems with my front bumper, and was wondering if any of you had this problem before and what was done to fix it. The problem that I have is that it squeaks real bad, and it sounds like I have singing birds inside my hood. I could grasp the bottom of the bumper and push it up and it seems real loose. I do know that the bottom skid plate or whatever its called was removed. So I'm thinking that's whey my bumper is so loose causing the noise. Does any one have any suggestions? Do aftermarket parts make you delete the skid plate?
Old Dec 27, 2011 | 07:27 PM
06RedRalli's Avatar
Any pics of how far off it is? From the factory there is a little gap between the headlight and the bumper so it's normal. The squeak might be the tab that is on the bumper right below the headlight is where it connects to, mine was not pushed all the way on and gave the same symptoms you're describing.
Old Dec 27, 2011 | 07:37 PM
EvoVIII_03's Avatar
Thanks for the reply i really appreciate it.
Yea there is a little gap bettween the bumper and headlight. If i could remember there is a clip on the driver side right underneath the headlight that was broken, but i could not do anything so i ended up putting a zip tight. I might have to take off the bumper and order that clip from mitsu. But is the bumper supposed to be that loose?
Old Dec 27, 2011 | 07:42 PM
Ryuartz's Avatar
hope this helps.
http://www.mitsubishiparts.net/catalog/?section=715
Old Dec 27, 2011 | 07:47 PM
EvoVIII_03's Avatar
hope this helps. http://www.mitsubishiparts.net/catalog/?section=715 __________________ EVO IX SE
Thank You it really did Now just to order them
Old Dec 27, 2011 | 07:58 PM
EvoVIII_03's Avatar
Here are some pics...now that i looked at it real closely it does seem like theres a huge gap
Attached Thumbnails Front bumper problems?-photo_4e103324-70f2-3408-2e64-e8ac73e313fc.jpg   Front bumper problems?-photo_de384ff0-096b-6155-a165-54bbad0c9c1b.jpg
Old Dec 27, 2011 | 08:11 PM
prowakeskater's Avatar
that gap looks a bit off, but it may be the angle. Can you take a pic of your entire front end?
Old Dec 27, 2011 | 08:15 PM
06RedRalli's Avatar
Seems just a tad off.
Ryuartz's Avatar
Wow. That does not look normal to me. Gap is too wide. Could you take pictures little further? I am not sure if clips can fix this. Take a look at http://www.evomoto.com/tech_articles...h_article_id=8 and see if your bumper is missing some fastener or bolts.
Old Dec 27, 2011 | 08:21 PM
EvoVIII_03's Avatar
Ill post some pics in a lil bit. Thanks for the help guys i really appreciate that you guys are taking your time to help me fix my problem
I think i need the clip that is in step number 6
Old Dec 27, 2011 | 08:25 PM
EvoVIII_03's Avatar
The gap seems to be more on the drivers side and not on the passengers side.
Attached Thumbnails Front bumper problems?-bumper.jpg   Front bumper problems?-photo_ec729951-4603-cadf-562e-c69cafaa36d0.jpg   Front bumper problems?-photo_01e1f6ec-b7ae-7652-2322-2e47164a5b66.jpg   Front bumper problems?-photo_cda12253-44e8-84fe-a421-311be0031fc4.jpg   Front bumper problems?-photo_5e8b3238-8cd4-c879-3a29-495da0507973.jpg
Old Dec 27, 2011 | 08:26 PM
i don't have that clip in step 6 and i don't have a squeak or that large of a gap.
may be worth looking into
Old Dec 27, 2011 | 08:30 PM
Ryuartz's Avatar
Ill post some pics in a lil bit. Thanks for the help guys i really appreciate that you guys are taking your time to help me fix my problem I think i need the clip that is in step number 6
HOw about step 9 clips?
Old Dec 27, 2011 | 08:38 PM
EvoVIII_03's Avatar
Yea i got both bolts and clips
__________________
Yea I dont have those on mine either, and there is no sign of there ever being a clip. I think that clip is just in the evo 9 front bumper. But ill look into that.
Old Dec 27, 2011 | 08:50 PM
Ryuartz's Avatar
In my opinion, it could be ETS intercooler rubs against bumper grill or something but I could be wrong. What size intercooler r u running? I heard size over 4" requires bumper modification.
