Needing help with gauges
Old Jan 3, 2014 | 12:46 PM
beat's Avatar
The EGT numbers amid greatly depend on where you mount the sensor. I think you want it as close to the head as possible.
Old Jan 3, 2014 | 04:13 PM
PureDrivePerformance's Avatar
Yes, true. It can vary @ 100* if you have it placed on top of the exhaust mani versus the bottom. The top will be hotter.
Old Jan 3, 2014 | 07:06 PM
Ckeesee12's Avatar
Originally Posted by foxbear2277
I like the Aem digitals alot. Not one issue with them. I like that there is a digital value always displayed but there is also a sweeping indicator around the exterior of the gauge face. I like defi's but they didnt have what I was needing and I didnt want to mix and match gauges in my car.
I measured the wires and used a power supply with terminal 15 (power only when key on)
I installed the fuel pressure sensor into my fuel rail. The oil pressure and temp should be taken by the oil filter.
Hope that helps
Thanks for all the help and advice! I definitely think I will be using fuel pressure instead of coolant temp. I may get a single A Pillar mount for coolant temp!
Thanks again!
Old Jan 3, 2014 | 07:41 PM
sr20det91's Avatar
This is my set-up to give you an idea of what the AEM gauges look like using a 42 draft design mounting plate.
Old Jan 3, 2014 | 08:00 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
For me these make the most sense in this order:
1. Boost
2. A/F -Wideband
3. Oil Pressure (You only need an idiot light for this, really. If pressure drops, it will be rapid and usually not when you're eyeballing a gauge. You just need to know when to put two feet in and kill the motor to save it.)
4. EGT
5. Oil Temperature
Old Jan 4, 2014 | 06:13 AM
Ckeesee12's Avatar
1. Boost
2. A/F -Wideband
4. EGT
5. Oil Temperature
Thanks! I'll be using the first three, and maybe as I get further into modding my car I may put in some additional.
Old Jan 4, 2014 | 06:14 AM
Ckeesee12's Avatar
Those are clean, I'm getting the bracket on lancershop thats tilts them towards you.
Old Jan 4, 2014 | 11:32 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
If you're going to get an idiot light for the oil pressure, you can use a Zeitronix set-up to activate the light when the pressure drops, so you don't need a fancy gauge.
Old Jan 4, 2014 | 05:39 PM
Ckeesee12's Avatar
I looked up idiot lights, and couldn't find one? (Does this make me the idiot? Lol)
Could you shoot a link my way?
Old Jan 4, 2014 | 05:50 PM
sr20det91's Avatar
Thanks. Only thing I don't like about the AEMs are that the LEDs only come in red. Wish there was a way to convert them to blue to match my HU and HVAC. I was looking at the lancershop one as well- I may switch out one day, but I can see them with no problem the way they are now.
Old Jan 4, 2014 | 06:23 PM
Ckeesee12's Avatar
My head unit changes colors, and my hvac is stock. I don't mind them being red, they'll stick out. I just ordered them today and am super excited!
Old Jan 4, 2014 | 07:23 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
http://en.wikipedia.org/wiki/Tell-ta...)#Oil_pressure
http://www.zeitronix.com/Products/zavt/zavt.shtml
Old Jan 5, 2014 | 01:14 PM
Ckeesee12's Avatar
Awesome, thanks!
Do they not come stock with an oil light? I don't really want the zeitronix setup. Just seems like more than I need, honestly.
Old Jan 5, 2014 | 04:42 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
There might be other solutions out there, you're just going to have to do some of that research yourself.
Old Jan 6, 2014 | 06:02 PM
iBoostEVO's Avatar
Have you looked into Innovate gauges at all? I currently have their wideband in my dsm. I definitly prefer it over the AEM wideband. I've had both. The Innovate unit reads much quicker and has a wider range. They also have a digital boost gauge and an oil pressure/oil temp in a single gauge. I think they're a bit cheaper than AEM as well, but not much.
