Question about Boost Gauge.
Old May 24, 2004 | 04:50 PM
Turbo Ghost's Avatar
I bought a Black Faced Defi D boost gauge.
I followed this helpful instruction.
https://www.evolutionm.net/forums/sh...ad.php?t=80842
My question is how do I know if my boost gauge works properly?
When I idle, the vacuum is about 19 to 20 psi. I searched the forums and it seems like that works ok.
When I am driving, if I were to accelerate normally (not mashing the pedal to the floor) to above 4,000 rpm, is the boost gauge supposed go to boost range? When I do that I don't see the needle go near the 5 psi in boost. It drops and hovers in the vacuum range.
But when I accelerate quickly (mashing the pedal to the floor), I see the boost rise up to 19psi. That I know it works.
Is that normal?
Old May 24, 2004 | 07:57 PM
GTVEVO's Avatar
if you are stock you are probably fine. You will find stock the car usually is in boost or out and not much in between. It will go into boost as the car gets into more load. But if you don't acc hard it won't boost much at all stock.
Old May 26, 2004 | 09:07 PM
Thanks. That's good to know. I thought there was something wrong with the boost guage.
Old May 27, 2004 | 04:39 AM
GTVEVO's Avatar
The one other thing that you can check just to be sure is when your car isnt' running the gauge must be sitting at zero. If the needle doesn't sit on zero it will be off as well but if it does I am 99% sure it is working correctly. Just somthing else I wanted to mention.
Old May 27, 2004 | 08:25 AM
mike_4G63's Avatar
Most of the time you will not be in anything other than vaccum since there is no load on the car unless you are giving it a good amount of throttle. When you hit it you will see boost jump up, and as soon as you let off the throttle you will see it dip back into vaccum. You should also notice that if you are in neutral and rev it up you wont be able to generate much psi. It's all related tot he amount of load on the car and the amount of throttle.
nerdbotSKRA
May 30, 2013 09:33 AM
funnieguy
12
Sep 1, 2011 05:42 AM
Alex Rodriguez
47
Feb 25, 2009 08:39 PM
beemerfreak
Jan 6, 2008 10:23 AM
simevo
Jun 13, 2004 05:43 PM
