Evo ix Front License plate Garnish Kit
Old Apr 16, 2009 | 03:09 PM
GG_EVO_IX's Avatar
Can someone confirm the correct part # for the ix garnish?
Old Apr 16, 2009 | 03:12 PM
MuslimEvoFreak's Avatar
Mine came with the exact hardware you describe. If you look underneath the front bumper (area where the intercooler is located) there should be a hole pre-drilled to attach the front garnish to.
veilside prius's Avatar
you have to order the hardware separately. I just ordered the plate bracket by itself from mitsubishiparts.com and it came without the hardware. They also have the part #s on the site.
Old Apr 16, 2009 | 03:13 PM
GG_EVO_IX's Avatar
Thanks for the quick replies
Old Apr 16, 2009 | 07:39 PM
SPEEDPIMP's Avatar
If your on Mitsu micro fische look 2 under your garnish part # (svc hard)
Old May 26, 2009 | 02:38 PM
theres no hole. I believe VIII is diff from IX
Old May 26, 2009 | 07:50 PM
WICKed'N'EVO's Avatar
I got ticket for no front plate too.... well I went to church and the Evo was parked right infront of my church and an idiot cop got any better to do than written me a ticket for no front plate.
Instead of putting my stock bracket and mounting hardware on I decide to custom made one. My Evo was never drilled,.. the moment I pick her up from the dealer she was a virgin ...lol so yeah finally after 3 yrs of ownership I got ticket for no front plate.
Anyway I found some alluminum sheet laying around so I decide to make a custom plate bracket.... I mount it on the almost same spot as OEM location but I did not drill from the front instead I drilled two holes from the under side which you cannot see from certain angle unless you look underneath it.
I'll post some pic and maybe make a how to thread later.
btw I went to the hearing officer and I did not got to pay anything since I got it mounted.... I guessing it must be some sort of fixer ticket.
Old May 26, 2009 | 07:53 PM
Either that or the stealership pre-drilled one?
Old May 26, 2009 | 09:52 PM
Here's my how to's:
If you hate drilling the 2-4 big holes on your front bumper what I recommend you to do is drill from the under side of the from bumper instead of the front side like oem.
here what I did....
Tool needed: Screw driver, License plate mount hardware, L-shape license holder bracket, drill, knife. oh yeah you can paint the plastic insert to match your car.
Your hardware and L-shape bracket should look something like these.
Step 1: Test fit before start. Mark all point before cutting..make sure you dont hit the crash beam. Now cut two square hole into the front bumper like this. Note: You need to measure and make sure how big your plastic screw insert before cutting.
Step 2: Now after you cut the two square hole.. insert the plastic screw inserts. It should make a poping noise comfirms that it pops right in. It looks like this:
With the screw on it looks like this:
Step 3: Finally attach your lincense plate bracket and screw the plate in. It should look something like this:
Front the top:
from the front view:
****You're all done... now get some to celebrate your easy 1, 2, 3 easy plate mount.
Old May 27, 2009 | 05:57 PM
tristat3's Avatar
very nice i likey
Old May 27, 2009 | 06:00 PM
borievoinitialD's Avatar
damn thats ingenious I bet you could make some money, making those sick front plate kit...
Old May 27, 2009 | 06:01 PM
btw I want your lip.. chargespeed ftw
Old May 28, 2009 | 09:33 PM
lol wish I could mass produce... for $10-15 shipped?
Thanks for the compliment.. I should mass produce it too heh. j/k
Old Jun 1, 2009 | 11:46 AM
evo<3's Avatar
i personally was not a big fan of drilling into my bumper( got a ticket just like you) i just used black zip times to zip tie it down to the screen (exactly where it is in the picture above^) and acutally doesnt look half bad and it worked in court soo if you dont wanna drill you could do that or fabricate something??
GL
Old Jun 1, 2009 | 02:35 PM
joon82's Avatar
Wow nice job.
I bet someone will mass produce this and resell for sure in the future.
