Power/boost loss?!
Old Jan 20, 2011 | 05:57 PM
vito's Avatar
Power/boost loss?!
So I was racing my friend, and everything seemed to go as planned, until I got to 5th gear. As I was nearing 5k rpm's, ready to shift to 6th gear, I hear a semi-loud pop. It sounded as if my uicp coupling came off (since I've had this happen before). I pulled over to check all the couplings and pipes to be safe. Everything seemed to be in place, so I continued my way. But, when I tried to floor it, I could definitely sense a power loss. I went up to 23psi with no trouble, but it didn't seem to run to its full potential as before.
I'm obviously a little clueless, and I was wondering if anybody had anything to contribute of help. I would greatly appreciate all the help I can get. I mean, the car seems to run just fine, oil was changed very recently, but the power loss is definitely noticeable.
Thanks in advance!
Old Jan 20, 2011 | 06:03 PM
milford's Avatar
go check your plugs, check all your couplers from the turbo to your throttle body. any new strange noises at idle or while driving?
Old Jan 20, 2011 | 06:07 PM
mifesto's Avatar
obviously you didnt check ALL the couplers if you did it from the side of a road. check by the turbo, licp and couplings going into IC.
Old Jan 22, 2011 | 06:32 PM
jdr7919's Avatar
Sounds like you may have had a coupler split on you. If everything looks ok.
I would do boost leak test to make sure your not missing anything.
03GS-T
Oct 23, 2016 09:55 PM
Headhunterz1105
Apr 8, 2016 11:01 AM
Icegod87
Sep 24, 2014 04:48 PM
michiganevox
Nov 8, 2010 07:33 AM
evolv
Jun 29, 2008 10:54 AM
