Get engine packages tailored for your Evo X build at STM!!!!
Choosing the right setup for your car can be really daunting and confusing with all of the piston and rod choices out there. Put the burden on those who know how to make cars go fast and do it again and again.
Rods and Pistons:
There are a dozen companies out there with choices for your car - Call us today and get a package tailored specifically for your setup and your goals, whether you're a 91 octane, pump gasser, trying to get the most out of what you can, or you're planning on running Import Race Gas or E98 all day long and want to find the limits of your block or crank.
Crankshafts:
There are a surprising amount of crankshaft choices out there - most of you can get away with a stock crank for the power levels you're looking at. Some of you will actually need an aftermarket crank that will hold the power you're squeezing out of your engine.
Give us a call and find the best possible price on the crank you need!!!
Camshafts:
There are dozens of cam choices offered by Kelford alone! Don't get lost in the back-and-forth between different cam choices. Let the experts help you into a set of cams that will suit your engine the best - Don't be held back by your cam choice, make the power you want and need by allowing your engine to breathe to its fullest extend.
Give us a call today and get the best prices on the best products for your car.
(585)226-8226
Rods and Pistons:
Crankshafts:
Camshafts:
(585)226-8226
