Insane Pricing on ETS turbo Kits and Blouch Dominator 2.0
When it comes to putting a bigger turbo or just bolt-ons on your Evo X, DG Motors has you covered with amazing prices on ETS Turbo Kits and Blouch Dominator 2.0's.
Blouch Dominator 2.0- Call or PM for COMPETITIVE Pricing!!!!!
Application: EVO X
Horsepower: 520
Bolt On: Yes
The Mitsubishi EVO X Dominator 2.0 is an outstanding performer featuring a proprietary state-of-the-art 52 lb/min Garrett GT compressor wheel (with an unheard of 79% maximum efficiency) combined with a race proven proprietary 11 bladed Garrett turbine wheel all wrapped up in a true Mitsubishi bolt on package. The Dominator 2.0 utilizes the very latest in Extreme duty thrust bearing technology that increases surface area, durability and oil flow to the turbo thrust surfaces. Our complete in-house machine shop performs all necessary machine shop operations to precise tolerances (no hacker work here) to maximize turbocharger efficiencies and provide our customers with the best possible product and customer service.
ETS Mitsubishi Evolution X T3 Twin Scroll Turbo Kit
If fast spool is what you need, then an ETS Twin Scroll Turbo Kit is what you’re looking for. A twin scroll turbo kit will typically spool the same turbo 300-500rpm faster than a conventional manifold design. This is accomplished by pairing the correct cylinders in the firing order together, so that the pressure waves arrive at the turbo 180deg apart, making a stronger impact upon the turbine wheel and thus accelerating the turbo faster. Another benefit of opposite cylinder pairing is that when one exhaust valve is open, the exhaust valves of the other cylinder in the pair are closed. 180deg. apart, helping spool the turbo quicker with no loss of top end power.Blouch Dominator 2.0- Call or PM for COMPETITIVE Pricing!!!!!
Application: EVO X
Horsepower: 520
Bolt On: Yes
Includes:
* Turbocharger
* Stainless Steel Downpipe
* Twin Scroll Exhaust Manifold
* Dual Mini 38mm TiAL Wastegate
* Wastegate Dump Tube
* Upper Intercooler Pipe
* Oil Feed and Drain Lines
* Water Feed and Drain Lines
* Turbo Gaskets and Hardware
* Clamps and Couplers
* Includes Everything Needed For A Complete Install
ETS Mitsubishi Evolution X T4 Twin Scroll Turbo Kit
Knowing how hard big T4 Turbos are to spool with a 2.0l engine, a twin scroll manifold is desirable for T4 based Turbos such as the GT40r, T04z, and the Gt35r-T4. The Large T4 exhaust sections of these turbos will make big power above 7000rpm, and the twin scroll pressure pulse manifold design helps spool these large turbos sooner than later. Utilizing dual wastegates, the exhaust pressure waves of cylinders 1&4 are kept separate of 2&3 so that they can impact the turbine wheels individually, 180deg. apart, helping spool the turbo quicker with no loss of top end power.Call or PM for COMPETITIVE Pricing!!!!!
Includes:
* Turbocharger
ETS Mitsubishi Evolution X T3 Turbo Kit
For serious power upgrades on the Evo 10 look no further than an ETS Turbo Kit. Packed with features like high flowing Equal Length ETS Manifold, true Merge Collector, full 3” Downpipe, direct routed Wastegate Dump, low angle turbo outlet, high flow upper intercooler pipe, Tial 44mm Wastegate, and any T3/T4 or Garrett GT series turbos, these kits will get the job done, street or track. Along with great performance, Features such as an exhaust flex, T-Bolt Clamps, 4ply silicone, and braided oil lines, will help make sure that you do not have to use the ETS Life Time Warranty!Call or PM for COMPETITIVE Pricing!!!!!
Includes:
* Turbocharger
* Exhaust Manifold
* 44mm TiAL Wastegate
ETS Mitsubishi Evolution X Intake
* 5" KN Filter
* ETS Milled MAF Adapter
* Perfrect Transition From Adapter To MAF
* Blow Off Valve Recirculation Tube
* Mounting Bracket
* BOV Vacuum Line
* All Couplers, Clamps and Hardware.
The ETS MAF Intake Includes a huge 5" inlet K+N air filter which feeds the intake pipe via the ETS EVO X MAF adapter which is milled on the ETS lathe for the perfect transition to the inlet diameter of the MAF sensor tube. With a built in dowel pin and precise inner diameter to make a 100% seal with the rubber grommet, this piece installs and fits as if it had a Mitsubishi part number. The system is then braced to the chassis with an aluminum bracket to ensure no movement or vibration. A single-piece mandrel bent 3" intake pipe makes the connection between the MAF and turbo with a smooth transition recirculation fitting for an easy connection to the BOV discharge.
ETS Mitsubishi Evolution X Turbo Back Exhaust
Features:
* Full Stainless Steel
* 3.0" Diameter
* 2x - 3.0" Straight Through Resonators
* V-band Clamp
* Perfectly Centered Tips
* Stock Mounting Location
* Includes All Hardware
Features:
* Direct Replacement
* J-Pipe O2 Bung (Prevents Check Engine Lights)
* Optional Wideband o2 bung
* Stainless Steel
Features:
* Split Wastegate and Exhaust Design
* Includes 5 studs and 5 nuts for easy install
* Includes Gasket
* Factory o2 sensor location
* Optional wideband bung available
ETS Mitsubishi Evolution X Intercooler Kit
* Pressure checked at 35psi.
* Bolt on design to retain crash beam.
* Fills entire grill with core.
* Full mandrel bent 2.5" piping.
* Stainless steel t-bolt clamps.
* 4-ply couplers.
* Includes all mounting hardware.
* Does not fit MR (Lower pipe)
* 20x12x3.0 Bar & Plate Core - 700hp Direct Replacement
* 20x12x3.5 Bar & Plate Core - 750hp Direct Replacement
* 20x12x4.0 Bar & Plate Core - 820hp Direct Replacement
The obvious tie-in between the UICP and LICP is the ETS EVO X Intercooler. Making certain to hold this unit to the standard of our EVO VIII/IX intercoolers, this unit is a tour de force in efficiency, distribution and flow. The factory inlet and out locations allow for the inlet and outlet to be at diagonally opposing corners of the core. This provides the best possible airflow distribution through the core's height making sure that all charge rows are used effectively. The AutoCAD drawn endtanks are as smooth as on our previous EVO intercooler with aluminum metal forming that looks more like artwork than endtank. Between the tanks is any one of our sizing options with 3", 3.5" or 4" intercoolers as BOLT-ON designs behind the factory crash beam and above the factory undertray. The intercooler is available separately or in a complete kit with UICP and LICP included and black anodizing, ETS stenciled logo, polishing and other options are all available!
Shaun@AWDMotorsports
EvoX 'For Sale' External Engine / Power
143
Jun 14, 2016 10:27 AM
ETS Michael
16
May 19, 2013 06:00 PM
ETS Michael
Mar 3, 2011 05:18 PM
ETS Michael
63
Dec 31, 2009 01:36 PM
ETS Michael
Nov 11, 2009 08:44 AM
