ETS Evolution X Turbo Kits!! (Single Scroll and Twin Scroll) - Billet Options!
Old Jan 6, 2010 | 04:21 PM
ETS Michael's Avatar
ETS Evo X Single Scroll Turbo Kit
For serious power upgrades on the Evo X look no further than an ETS Turbo Kit. Packed with features like high flowing Equal Length ETS Manifold, true Merge Collector, full 3” Downpipe, direct routed Wastegate Dump, low angle turbo outlet, high flow upper intercooler pipe, Tial 44mm Wastegate, and any T3/T4 or Garrett GT series turbos, these kits will get the job done, street or track. Along with great performance, Features such as an exhaust flex, T-Bolt Clamps, 4ply silicone, and braided oil lines, will help make sure that you do not have to use the ETS Life Time Warranty!
This is the exact kit we made 620whp on a stock evolution x motor using a T3 35R with a .63 a/r turbine housing and 730whp using a built 2.0L motor and maxing out an HTA3586 with .82 A/R Turbine Housing.
ETS Mitsubishi Evolution X Single Scroll Turbo Kit
ETS Evo X Twin Scroll T3 Turbo Kit
If fast spool is what you need, then an ETS Twin Scroll Turbo Kit is what you’re looking for. A twin scroll turbo kit will typically spool the same turbo 300-500rpm faster than a conventional manifold design. This is accomplished by pairing the correct cylinders in the firing order together, so that the pressure waves arrive at the turbo 180deg apart, making a stronger impact upon the turbine wheel and thus accelerating the turbo faster. Another benefit of opposite cylinder pairing is that when one exhaust valve is open, the exhaust valves of the other cylinder in the pair are closed. 180deg. apart, helping spool the turbo quicker with no loss of top end power.
ETS Mitsubishi Evolution X T3 Twin Scroll Turbo Kit
ETS Evo X Twin Scroll T4 Turbo Kit
Knowing how hard big T4 Turbos are to spool with a 2.0l engine, a twin scroll manifold is desirable for T4 based Turbos such as the GT40r, T04z, and the Gt35r-T4. The Large T4 exhaust sections of these turbos will make big power above 7000rpm, and the twin scroll pressure pulse manifold design helps spool these large turbos sooner than later. Utilizing dual wastegates, the exhaust pressure waves of cylinders 1&4 are kept separate of 2&3 so that they can impact the turbine wheels individually, 180deg. apart, helping spool the turbo quicker with no loss of top end power.
ETS Mitsubishi Evolution X T4 Twin Scroll Turbo Kit
ETS Evo X Turbo Kit Intake
Dyno Graphs:
Standard 35R w/ .63 A/R
HTA3586 w/ .82 A/R Exhaust Housing
HTA3586 T3 Twin Scroll vs FPRED (Both Cars 93 Octane @ 25psi)
Dyno Threads:
https://www.evolutionm.net/forums/ev...ht=ets+hta3586
https://www.evolutionm.net/forums/ev...tang-dyno.html
https://www.evolutionm.net/forums/ev...l-ets-kit.html
https://www.evolutionm.net/forums/ev...it-681whp.html
https://www.evolutionm.net/forums/ev...pump-93-a.html
https://www.evolutionm.net/forums/ev...new-pixth.html
https://www.evolutionm.net/forums/ev...ane-video.html
https://www.evolutionm.net/forums/ex...0whp-pump.html
https://www.evolutionm.net/forums/ev...-system-x.html
Thanks!
Michael
Old Jan 7, 2010 | 01:53 PM
We can build the turbo kits with PTE, FP or Garrett turbochargers
Few Popular Turbochargers
PT 5857 Billet
PT 6057 Billet
PT 6262 Billet
PT 6765 Billet
FP HTA 3076
FP HTA 3582
FP HTA 3586
Garrett 3076
Garrett 3582
Garrett 4088
Twin scroll options are currently available for FP and Garrett Turbos.
Thanks!
Michael
Old Jan 15, 2010 | 02:33 PM
Bump!
Old Jan 21, 2010 | 05:22 PM
Bump!
Old Jan 25, 2010 | 05:18 PM
Bump!
Old Jan 28, 2010 | 09:52 AM
Bump!
Old Feb 3, 2010 | 04:47 PM
Bump!
Old Feb 8, 2010 | 05:32 PM
younggindamix's Avatar
pm lowestprice fp hta 3586 ts evo x
Old Feb 9, 2010 | 03:04 PM
RB185AFM's Avatar
Michael,
Can you pm me the lowest price on a HTA 3586 single scroll. Not sure I will have enough to do a build with your kit but would like to make sure before I pull the plug on a BBX or FP Red. Shipping would be to 94565.
Thanks,
Robert
Old Feb 9, 2010 | 03:07 PM
WWIXMR's Avatar
*Boing*
Old Feb 10, 2010 | 11:13 AM
Pm's Sent!
Old Feb 11, 2010 | 03:25 PM
Bump!
Old Feb 11, 2010 | 08:39 PM
RB185AFM's Avatar
Michael,
Will my Harmon intake work with your 6262 single scroll kit or will I need your intake? I am assuming the turbo inlet is just a little bit bigger that the stocker.
Old Feb 12, 2010 | 05:50 AM
streetdreams552's Avatar
I sent u a pm regarding your manifold!
Old Feb 12, 2010 | 08:22 AM
Originally Posted by RB185AFM
Michael,
I don't think the Harmon intake will work since the turbo is in a different location. It's best to go with our turbo kit intake, since it's 4.0" and matches the inlet on the compressor cover.
You might be able to adapt the Harmon intake, but I'm not sure if it's possible or what it will require.
PM coming your way sir! Good talking with you on the phone.
Michael
