RallySport Direct Koyo Aluminum Racing Radiators Evo X
RallySport Direct
Evo Koyo Aluminum Racing Radiator's are here and in stock!!!
Koyorad's philosophy "Contributing technology to create a higher standard". Koyorad is leading the world in the automotive radiator aftermarket,
a core component in the automobile industry. With the phenomenal growth we have attained, Koyorad has set goals to reach a new level of
achievement. Koyorad, in its quest to be a global corporate citizen is thru its heat exchange technologies wholly dedicated to creating a better
world, with a special emphasis on value and a vision
Koyo Aluminum Racing Radiator Mitsubishi EVO X 2008-2014
Click HERE for pricing and to purchase Evo X Koyo Radiator
Koyo aluminum racing radiators are designed to be direct factory replacement units. Koyo racing radiator features
a much thicker core with a more efficient fin design that helps with flow and temperature drop over the surface.
Koyo is Japans largest aftermarket radiator manufacturer, utilizing the latest aircraft quality aluminum and Heli-arc welded.
Heli-arc soldering is the highest quality standard for enforcement along aluminum connections.
The Koyo radiator is roughly 20mm thicker then stock, allowing for larger capacity, better flow,
and faster heat loss over the surface of the core.
Remember that you get FREE Ground shipping on all orders over $200 in the continental USA
Please let us know if you have any questions on these
Thank you,
Dallin
