Grimmspeed External wastegate block-off plate for Evo X
Grimmspeed's external wastegate block-off plate is a simple bolt-on solution for those of you who may not be able to purchase everything necessary for a full external wastegate setup up front. After using the block-off plate, this will allow the EWG up-pipe to run without the wastegate. Once the wastegate is purchased, the EWG block-off plate can be easily removed. Grimmspeed's EWG block off plate is made from 304 stainless steel and comes with a V-band clamp to complete the install. \
Please send us a PM to set up an order with your zip code for an accurate quote. Please note that there are two versions of the block off, a 44/45mm and a 38/40mm version; you will need to specify which version you need when ordering.
