ExtremeTurboSystems.com – WA Custom Intercoolers, Intercooler Kits, Turbo Kits and Performance Parts. [Visit Site]
bad mbc or wastegate?
Old Apr 21, 2008 | 02:31 AM
spooch's Avatar
i installed the ets 57 trim kit and today tried to up the boost.. the mbc was all the way down and i hit 16-18psi... ididnt pay 100% attention. no matter what i do, every click or turned all the way or half way up the boost wont change. i even toook off the line going to the wastegate from the mbc and no change
whats wrong here?, car is supposed to go on the dyno 2morw and i dont want to have any problems
boost leak was done and just a minor one at the throttle body seals,. nothing that would effect that much
Old Apr 21, 2008 | 05:42 AM
heyzeus11's Avatar
Sounds like you might have the MBC, setup wrong with the tial wastegate? This page should have the install instructions for the wastegate,
http://www.tialsport.com/prod_wg.htm
Old Apr 21, 2008 | 07:47 AM
xiaoni420's Avatar
Make sure that you have the boost line going to the wastegate attached to the TOP of the wastegate. Take some pics of your current setup. I don't believe that your boost controller would have all of a sudden taken a sh*t, but it's always possible I guess.
Old Apr 21, 2008 | 08:24 AM
ETS Michael's Avatar
If you're still in need of assistance hooking it up just give us a call
Tom
Old Apr 21, 2008 | 10:11 AM
SickSilverNLow's Avatar
i agree with Nick...make sure things are where they are suppose to be.
Old Apr 21, 2008 | 10:19 AM
SPEED's Avatar
Check your wategate springs. Same problem I had with the TT50trim. They had two wrong springs in it.
Old Apr 21, 2008 | 02:41 PM
spooch's Avatar
tried every possible line combination, including top port on wastegate and nothing so im not sure what the hell it is
Old Apr 21, 2008 | 02:47 PM
just give Tom a pm or call him up....he will be able to help you. Tom is the man .
Old Apr 21, 2008 | 02:49 PM
xiaoni420's Avatar
Go ahead and disassemble your MBC and take the ball and spring out of it, then replace both as they were. Sometimes the ball and/or spring gets stuck which will not allow you to adjust your boost.
Old Apr 21, 2008 | 02:51 PM
spooch's Avatar
talked to tom, possibly its the mbc so well have to check things out
Old Apr 21, 2008 | 07:24 PM
Felginator's Avatar
What MBC are you running?
Old Apr 21, 2008 | 07:25 PM
spooch's Avatar
turned out to be my greddy dv
galantman03
43
Feb 5, 2017 09:54 PM
MajesticOne
Nov 20, 2016 02:34 AM
spooch
11
Apr 21, 2008 09:09 PM
mscorei
20
Mar 5, 2008 06:45 PM
Boost3dxEvO
Jan 8, 2008 12:48 AM
