ExtremeTurboSystems.com – WA Custom Intercoolers, Intercooler Kits, Turbo Kits and Performance Parts. [Visit Site]
ETS Corn Lovers Sex.(SC61 on E85)
Old Jul 24, 2008 | 03:01 PM
Turbo Kyle's Avatar
I went over for a ride in Mikes SC61 powerd E85 Monster. The Clutch was out the door so we were only on 20 psi....but holy jesus that thing is nasty. He has the ETS Supervalue kit, 272s, FMIC and some other BPUs....can wait till the new clutch is in...I want a ride on 30psi...should be good for another 100hp!
Old Jul 24, 2008 | 03:58 PM
SickSilverNLow's Avatar
This thread is worthless without a vid.........J/K.
Must have be one hell of a ride .
Old Jul 24, 2008 | 04:02 PM
Billy@EnglishRacing's Avatar
sounds good but we do need pics and video!
Old Jul 24, 2008 | 04:07 PM
Turbo Kyle's Avatar
Ill get it next time out...The car reminds me of my buddys 66mm Supra. That darn E85 is wicked...I need to order some injectors.
Old Jul 24, 2008 | 04:10 PM
what injectors are you running now??
Old Jul 24, 2008 | 05:15 PM
Turbo Kyle's Avatar
Im running Stock (im on gas)...my buddy with the E85 Car is running 1000cc...he needs bigger ones and twin pump.
Old Jul 24, 2008 | 05:16 PM
what is he seeing in the way of duty cycle?
Old Jul 24, 2008 | 05:17 PM
on by buddy's ets 57 kit with 1200's and a single 255 on e85, we are only seeing between 80-85%
Old Jul 24, 2008 | 06:42 PM
[EVO]Cookie's Avatar
I'm going to try to get the clutch in this weekend once I can get some more boost going I will get the duty cycles. It has RC 1000.... I run out of fuel past 30psi and 8k....(I just mean that I'm starting to lose fuel pressure past that boost and RPM) the car will just scream to 9K so I want to do something with the fuel pump...... I need a bigger pump or a second pump for more boost. I want to be able to run strait Methanol or maybe a E85 mix for track only runs. I can say at 30psi it's more power than I want to drive on the street.
Old Jul 25, 2008 | 09:22 AM
i have an a1000 that i could get to you pretty cheap if you decide to go real big
Old Jul 25, 2008 | 03:08 PM
Just curious I've looked at those, has anyone you know of run those off the stock ECU. You know on the stock ECU controlled relay set up. I really didn't want to have a toggle switched fuel pump.
Old Jul 28, 2008 | 08:32 AM
ETS Michael's Avatar
Corn powered FTW! That turbo really wakes up on the bigger boost so E85 is perfect for a DD. I'm so glad we have a few stations here, lots of other areas aren't so lucky.
Tom
Old Aug 1, 2008 | 10:05 AM
dsmfan95's Avatar
Originally Posted by ETS Tom
Corn powered FTW!
Tom
If my current setup doesn't put me where I want, I'm going to part it out for an ETS 35R Kit
Old Aug 1, 2008 | 10:07 AM
still need to talk to johnbradley about this, i will see him tonight
Old Aug 1, 2008 | 10:59 AM
dsmfan95's Avatar
Would a Hobbs switch be considered a toggle switch? That's what I run on my twin pump setup.
