MR bov?
Old Sep 24, 2004 | 08:35 AM
evo8MR's Avatar
MR bov?
so is anyone sure if the MR edition is going to have the plastic bov or the metal one? I think im going to order the metal one if it comes with plastic cause i have read good things about the jdm one.
Old Sep 24, 2004 | 08:36 AM
Greg K's Avatar
I wouldn't worry about it. If it has the plastic one and it leaks then upgrade. There is no real difference in the 2 other than the "bling factor" of saying you have the MR one.
YMMV,
Greg
Old Sep 24, 2004 | 10:44 AM
EVOTEXAS's Avatar
YMMV,
Greg
That's totally wrong. My MR valve holds my boost MUCH better than the stock plastic one. They are different internally also. Not a lot of bling there is there? Unless you take it off all the time to show your friends.
Old Sep 24, 2004 | 10:50 AM
evo8MR's Avatar
bling bling.....so the MR edition will be coming with the plastic one correct?
Old Sep 24, 2004 | 11:07 AM
Greg K's Avatar
will not hold any more boost than the computer will allow it to... he didn't mention that the he's upgrading the computer, or installing a boost control.
Old Sep 24, 2004 | 01:27 PM
EVOTEXAS's Avatar
Irrelavant. Regarding the funconality of a BOV/DV, the MR works better than the stock GSR valve. It hold the boost you give it better. The stock valve can't even hold stock boost!
Old Sep 25, 2004 | 06:47 PM
thatsMR2u's Avatar
wouldnt putting in a MR bov void ur warranty even if u have an MR-edition, cant you just put a stronger spring in the stock bov?!
Old Sep 25, 2004 | 08:25 PM
-130 R-'s Avatar
Clarification points:
1) The US MR has the same plastic BOV as all the other US Evos. I saw it in person at a meet a few weeks ago.
2) The MR DV holds boost MUCH better. I am running a boost gauge/controller and when I installed the MR valve, it jumped from 1.4 KPa to 1.55 KPa. That is significant. I've since adjusted it to 1.4 KPa again.
3) Not really bling since it's buried under a lot pipes and hoses (making it a ***** to install). Wasn't really impressive when I took it out of the box, but the spring is much stiffer than stock.
Hope that helps.
Old Sep 25, 2004 | 10:06 PM
evo8MR's Avatar
great info, does your car sound any different with it on as oppose to the plastic one.
Old Sep 26, 2004 | 09:24 AM
-130 R-'s Avatar
Sound is almost exactly the same. I have an open element air filter, so I could hear the stock one, too. No big change in the sound. Just a very noticeable difference in holding boost.
Old Sep 26, 2004 | 09:44 AM
GPTourer's Avatar
Yes. But it depends on how closely your car is scrutinized.
Probably not. The stock Evo plastic one reminds me of the stock 2G BOV, except its a little better. Not worth fooling with.
Old Sep 28, 2004 | 12:18 AM
Jakeg97's Avatar
oohhh where can i get the mr diverter valve?? will this void my warrenty? i need it to look better than my stock non mr diverter valve. so people can see it when i drive around with my hood off
Old Sep 28, 2004 | 10:57 PM
evo8MR's Avatar
wise guy.........lol.........it holds boost better than pos plastic one
