Article on the new MR [MERGED]
Old Jun 9, 2004 | 12:20 PM
patsevo8's Avatar
Here it gives a overview of the 3 new MR's being put out, and only one of them coming to the U.S.
Mitsubishi Evo VIII MR FQ-340
Many detail improvements and 345bhp make the MR the best Evo yet
'll answer the very obvious question first. Yes, the most potent Evo MR is chuffing fast. It piles on speed so relentlessly that by the time you've got to fifth on your first rush up the 'box, you're wondering if it would just keep on charging forward if it had seven or eight speeds. It's not spiky power, either - from around 3500 to 7500rpm the push is strong, clean and consistent, and the ramp up to full boost is rapid yet progressive.
In other words, the MR FQ-340 is blindingly fast but not madly frantic, relatively speaking. We've driven other 300bhp-plus Evos that rearrange your lunch every time they hit boost (our 320bhp lightweight Evo VII RS long-termer of a couple of years back springs to mind). This is its own kind of thrill but it can distract the chassis, tugging the front wheels around or kicking the tail out when you'd rather keep things tidy.
The MR (which stands for Mitsubishi Racing) is effectively an Evo 8.5 and incorporates many detail revisions. Some contribute to it being 10kg lighter than the straight VIII, including aluminium door intrusion bars (-3.5kg) and roof (-4kg). The latter is said to have the same effect as lowering the steel roof by 50mm. UK models also get 12-spoke Team Dynamics alloys, which save 0.8kg of unsprung weight per corner over the standard Enkei alloys.
All these incremental improvements contribute to the dynamic performance of the MR but the most significant effect is probably the switch to Bilstein dampers. Compression and rebound rates have been respecified and the rear bump stops have been reshaped. The Evo's formidable armoury of electronic chassis aids has also seen changes. Previously, when anti-lock was activated the Active Centre Differential and Super Active Yaw Control were disengaged. Now they are integrated into the braking effort to help keep the car stable should you jump on the middle pedal mid-corner or trail-brake into a turn.
MR models aren't Euro-homologated like the Evo 260, but unlike previous Japanese-spec cars, they do get the full three-year pan-European Mitsubishi warranty. The MR range comprises the FQ-300 (305bhp, £27,999), FQ-320 (326bhp, £29,999) and FQ-340 which has 345bhp, 320lb ft of torque and costs £32,999. That looks like a big premium over the FQ-320 but you also get leather and Alcantara trim (a lesser hide interior costs £1535 on other Evos) and Smartnav (normally £524). Four colours are offered: white, red, silver and gun- metal grey (shown), which works beautifully with the MR's new matt- black-backed clear-lens lamps, badging and dark grey alloys.
Inside, the cabin is little changed save for strips of carbonfibre-effect trim, but the ambience of the FQ-340 is much enhanced by the Jaguar-like aroma of leather. The Ralliart-embroidered Recaros grip tightly, which is just as well because the cornering powers of the MR Evo seem higher than ever.
Compared with just about anything else, the Evo still feels hyper-active on a bumpy B-road but although the ride remains firm, right away you notice that there isn't quite as much fidget and distraction as there was. It seems to be partly the ride but more the steering, which feels a little less sensitive around the straight-ahead. You appreciate this most when you've got the throttle down and the chassis is loaded with full boost.
The handling is every bit as responsive and agile as it ever was, and grip from the broad-blocked Yokohama Advan A046s is huge. Dive keenly into a tight second- or third-gear corner and the nose will tuck into the apex with an enthusiasm that threatens to send the tail sliding out. Do nothing and full stability is resumed, calmly. Bury the throttle, though, and the response of the clever chassis is breathtaking; the rear slip is smoothly reined in, all four tyres haul hard and the MR fires out the other side at astonishing speed.
No question, of all the mega-fast Evos we've tried, the MR FQ-340 is the neatest and most driveable. The essential character of the Evo remains intact but there's a greater sense of composure, which is all the more impressive given the power and torque the FQ-340 upgrade asks it to cope with. The Evo evolution continues apace.
Old Jun 9, 2004 | 12:22 PM
Mister2zx3's Avatar
Where is this from?
Old Jun 9, 2004 | 01:07 PM
Tanner_Hall's Avatar
actually, none of them are coming to the us. the usdm MR will be different - refer to the now-official specs.
Old Jun 9, 2004 | 01:42 PM
bullfrg's Avatar
Originally Posted by patsevo8
UK models also get 12-spoke Team Dynamics alloys, which save 0.8kg of unsprung weight per corner over the standard Enkei alloys.:
Are these the same TDR wheels a bunch of just got? I wonder if the gray ones are the same Anthracite color that I got for my BBY Evo? Do you have pic from this article?
Old Jun 9, 2004 | 01:50 PM
slt's Avatar
slt
Wouldn't that be wild. Someone post a pic!
Old Jun 9, 2004 | 08:30 PM
patsevo8's Avatar
pics of the MR.....
CHECK OUT THIS SIGHT TO GET PICTURES
http://www.evo.co.uk/driven/driven_story.php?id=47318
Old Jun 9, 2004 | 08:34 PM
batty's Avatar
Ok its the FQ340 something AMERIcA WIll never see!
Old Jun 9, 2004 | 09:39 PM
slt's Avatar
slt
Edit: stupid thread merging
Old Jun 9, 2004 | 09:41 PM
slt's Avatar
slt
How messed up is that. I have those very rims on my car right now TDR's baby!
Old Jun 9, 2004 | 09:47 PM
slt's Avatar
slt
Old Jun 9, 2004 | 09:50 PM
LancerEvoMR's Avatar
Moving to Future Evo Models.
Old Jun 10, 2004 | 07:17 AM
bullfrg's Avatar
They sure look like it, I guess that is pretty cool. I wonder if we can get those center caps for our wheels. That we be a cool addition to our wheels.
Old Jun 10, 2004 | 07:45 AM
gtr's Avatar
gtr
What is the sizing, price and weights for those wheels? And where to buy?
Old Jun 10, 2004 | 07:57 AM
bullfrg's Avatar
The wheels are the same size as stock 17x8 with a 35mm offset, they weigh in a couple lbs. lighter then the stock rims at 19 lbs. Tswift on the forums was selling them for $190 each which is cheap with $10 shipping per wheel. Last time I heard he still had a set or two left. There is a big thread with most of this info under wheel and tire section plus a few of us posted pics in show and shine. Let me know if I can help you with anything else.
MikeB
Jan 27, 2017 03:02 PM
ak47po
38
Aug 8, 2008 02:16 AM
boy36
Dec 29, 2007 01:46 PM
Ÿêõ
Future Lancer / Evo Models
82
Jan 13, 2005 12:01 PM
EVOJOE
10
Mar 28, 2003 11:19 AM
