Will the new 6-speed help in the 1/4 mile?
Old Aug 9, 2004 | 05:33 PM
  #31
1QWKEVO's Avatar
NEvermind I do stand corrected, for some reason I was under the impression I saw that it had a lower first gear, but it instead changes the gearing throughout the 6-speed and adds a taller 6th gear....
So as far as 1/4 mile it will still launch pretty much the same and you should finish the 1/4 in the bottom of 5th... my guess is you will ahve to shift into 5th due to the fact that the 6-speeds 4th is lower then the 5-speeds...
Old Aug 9, 2004 | 07:47 PM
  #32
Tanner_Hall's Avatar
^^no.
Old Aug 9, 2004 | 07:55 PM
  #33
1QWKEVO's Avatar
Originally Posted by Tanner_Hall
^^no.
care to elaborate?
if i'm not mistaken don't we finish in the top of 4th with our 5-speeds?
Old Aug 9, 2004 | 07:57 PM
  #34
sorry, it's just that the info was posted earlier in this thread. the mr's 4th tops out over 110 mph. unless it's modded, it's not gonna trap higher than that.
Old Aug 9, 2004 | 08:01 PM
  #35
1QWKEVO's Avatar
well if thats the case then the diffs are geared different... let me look back at the MR's gearing
even the final drive is higher then the 5-speeds...
Has anyone ran a 1/4 mile in the 6-speeds yet, that would prob answer all of our questions
Old Aug 9, 2004 | 08:06 PM
  #36
Ludikraut's Avatar
Yep... if you are making enough HP you will definitely need 5th. Some of the stronger Evo's already do.... FWIW, 4th gear is only good for ~120mph if I remember correctly.
l8r)
Old Aug 15, 2004 | 11:34 AM
  #37
MiSTER2's Avatar
So will the 6th gear help evo reach higher top speeds??? Or are we destined to get beaten by any performance car that has 3litre or bigger engine on the highway???
Old Aug 15, 2004 | 02:10 PM
  #38
SuperHatch's Avatar
The 6-Speed's 6th is taller (numerically lower) than the current 5-Speed's 5th, and the 6-Speed's 5th is shorter (numerically higher) than the current 5-Speed's 5th. Both trannies 4th gears are nearly identical. So yes, a higher top speed is possible with the 6-Speed and better acceleration due to closer gears on the top end will help as well.
- Steve
spam2012
Apr 3, 2017 08:31 AM
slowsrt4:(
Aug 24, 2014 07:31 PM
tuffguy
Jul 20, 2005 09:49 PM
DynoFlash
Jun 26, 2005 04:49 PM
