Mounting Solutions S-AFC
Old Dec 24, 2004 | 10:48 AM
Turbocake's Avatar
you can use double sided tape to mount the base to the yellow sticker inside your glove box. this makes it somewhat difficult to reach (i just set it and leave it) but it's totally out of sight.
Old Dec 24, 2004 | 10:52 AM
GTVEVO's Avatar
When I was running the SAFC I had mine mounted in the sunglass holder up above, it was easy to see as any other place really and it could be hidden away when needed.
Old Dec 28, 2004 | 07:58 PM
megatron's Avatar
Originally Posted by RuckerPark
I did the same
can you post a pic of this? i want to place mines there too but how would you access the ash tray? i keep coins in there.
Old Dec 28, 2004 | 08:37 PM
mattfl's Avatar
mine
Old Jan 6, 2005 | 02:01 PM
03BREvo8's Avatar
mines mounted in the clove box... no need to look at it when its tuned right....
Just looking at the other posts and in one signature i saw a carbon fiber cat back...
ok i might be seeing things but i dont think ive ever heard of a carbon fiber catback.. wouldnt the thing just meld away at such extreme temps... am i missing something here?
Old Jan 6, 2005 | 02:03 PM
tokeone's Avatar
i velcored mine right in front of the hazard light button
Old Jan 24, 2005 | 06:02 PM
aeirlera323's Avatar
for those of you who mounted the safc in the sunglass holder, where did you run the wires through? any pics? thanks
Old Jan 25, 2005 | 06:17 AM
ldstang50's Avatar
rexorz
I mounted mine in the sunglass holder. I ran my wires up the A pillar on the passenger. I pulled the plastic trim and ran the wire up alon the other wires that are there and ziptied my afc wires to those. I then pulled down the ceiling a little and ran my wire up over it. I also removed my sunglass holder and cut a little hole for the wire to pass through. The holders tracks will pinch the wire so I had to cut a little hole. Its very minor and you can't even tell its there.
The wiring was real easy. I'll see if I can't take some pics and show it to you tonight
Old Jan 27, 2005 | 08:16 PM
Originally Posted by ldstang50
rexorz
have you taken those pics yet?
Old Jan 28, 2005 | 05:19 AM
ldstang50's Avatar
ya i gotta load them on the comp. I won't have time today cause I'm leaving for CT after work today. My grandmother isn't doing so well. But I'll try to do it on sunday when i get back.
Old Jan 28, 2005 | 05:25 AM
o3evo8's Avatar
Veteran: Air Force
Old Jan 28, 2005 | 10:37 PM
do you have any pics of the whole installation
Old Feb 5, 2005 | 08:22 PM
ldstang50's Avatar
Here is where I mounted my afc, I took out my passanger side a-pillar and there is a hole already on that side to drop the wires through. I also ordered a ecu wire extension harness and pre-wired everything so it made for a simple plug and play when I got it into the car. Dont forget you will need to drop the headliner a bit to run the wires and pop the sunglass holder out to send the wires through.
Attached Thumbnails Mounting Solutions S-AFC-afc.jpg   Mounting Solutions S-AFC-afcwires.jpg
Old Feb 9, 2005 | 02:22 PM
ldstang50's Avatar
bump, people wanted to see the wiring for someone that had the afc in the sunglass holder
Old Feb 9, 2005 | 05:06 PM
thanks for the pic.
