New Dyno Resutls via UTEC Tune
Old Nov 10, 2004 | 10:07 AM
ArchieBabes's Avatar
I got my car dynoed yesterday and it made 310whp on 91 Pump gas and it made 350whp on 96-97 Gas. It was a blend of 5 Gallons of Race gas and 1 Gallon on 91 Pump Gas
Car was tuned via UTEC on a 4wd Dyno
Just wanted to compare my dyno results, if they are consistent.
Thanks
Old Nov 10, 2004 | 10:11 AM
Imprezd's Avatar
What mods?
Looks good though.
Thanks,
Jermaine@turboxs.com
Old Nov 10, 2004 | 10:26 AM
Here are my mods:
1. Full Turbo Back 3inch Exhaust
2. Cone Filter
3. Intercooler Pipings
4. Larger Intercooler
5. 660cc Injectors
6. 255lph Fuel Pump
7. HKS 264 272 Cams
8. HkS Camgears
9. MBC
10. UTEC
Thanks
Old Nov 10, 2004 | 10:49 AM
MalibuJack's Avatar
If I recall those numbers were really close to the Data Log Lab estimates we made a while back, weren't they?
Old Nov 10, 2004 | 10:56 AM
I think so, it was realy close...
Do you think that the gains I made is just right for my current setup of mods?
What other mods do you think I can bolt on to reach at least 380whp?
Thanks MalibuJack
an0ther's Avatar
Looks good. I made 281 on 93oct dyno tuned. I had Utec/turbo back "stock cat" and turboxs filter. Sold my utec now because I need the money
Old Nov 10, 2004 | 11:05 AM
an0ther's Avatar
Just wanted to let everyone know that with boost solutions gone in atlanta, some people are having a hard time finding awd dyno and tuners. Just wanted to say that I took my car to "Knowledge performance." They are in Kenessaw GA. They dyno tuned my utec on their awd dyno. You should go check out the shop if you are near there. They have some nice project cars up there including a 550 whp wrx with sti block, and they always have stuff in stock for our evo's I know you can find stuff cheaper online, but everyone knows you buy stuff spur of the moment.
Old Nov 10, 2004 | 11:08 AM
Stinkapuss's Avatar
Very nice!
Old Nov 10, 2004 | 11:30 AM
BlackEVO's Avatar
Really? I haven't put much faith in the DLL dyno thingie, other than to see relative changes when tuning. Were you using 3rd gear pulls and what weight/dyno settings? Maybe my car is making more power than I think it is...peak TQ on the DLL still seems low to me, but I log/tune mostly on the same damn slight uphill grade.
Archie, nice job. I have very similar mods and would be curious to see your pump gas map (or log) if you care to share it. I think mine is pretty decent, but I always like to compare to others....especially if there are dyno charts to back them up cuz I haven't been on one yet
Old Nov 10, 2004 | 11:42 AM
MalibuJack's Avatar
What boost did you end up running? I think if your running race gas, you probably can get away with a bit more boost to bring you close to 380, I think at this point you have to identify additional restrictions, Throttlebody might be a good start, header, 10.5 turbine housing, O2 housing maybe.. That should get you close to that target..
Old Nov 10, 2004 | 11:48 AM
MalibuJack's Avatar
Yeah the peak torque seems low to me too.. But one thing I noticed is his mods are similar to mine at the time I was doing alot of tuning with DLL a few months ago and the pump gas numbers in DLL are damn close to that... IT just seems that reducing restrictions seems to have a greater net effect in the scheme of things than just the mod itself.
Old Nov 10, 2004 | 12:05 PM
The boost is set at 23.5psi tapering down to 20 - 21 psi by redline.
Any ideas on how to bring up the torque curve?
Thanks Again
Old Nov 10, 2004 | 01:21 PM
BlackEVO's Avatar
Yeah, I've tried every which way to increase peak TQ numbers (including going to a 264/264), but the most I've seen yet in DLL is about 325. It usually hangs around 317ish...guess I'll just need to work on increasing/flattening the curve over all.
DLL is like 5HP/TQ "close" or like 15?
Well, in my air box test (with/without) I had to swap from the RMR filter to a PE filter. It took about 2 logs before I noticed that my peak MAF readings were down almost 100Hz. Not written in stone, but an indicator of flow none the less. I am not really sure if it is the filter or the cast adapter (leaning more towards this). On the RMR, I was closing in on 2000Hz (1965-1980) and I have all I can do to crack 1900 now. I am going to see if there is a way to make the RMR filter kit work with the Apex box and see what happens. Just to clarify: I am not knocking the Apex box/PE fitler, DLL dyno #s are not noticeably diff between the two filters after tuning regardless of change in MAS readings...
Old Nov 10, 2004 | 01:31 PM
VTECH8TR's Avatar
Originally Posted by ArchieBabes
Here are my mods:
2. Cone Filter
5. 660cc Injectors
6. 255lph Fuel Pump
7. HKS 264 272 Cams
8. HkS Camgears
9. MBC
10. UTEC
Thanks
Archie,
Nice results man.
Old Nov 10, 2004 | 06:11 PM
MalibuJack's Avatar
Well, its like comparing any other dyno.. but as long as you get your corrections right, you should be around 10whp/tq to a dynojet with similar corrections.
