Modified injector size
If I change the modified injector up and leave the stock at 550, thats supposd to lean the injectors out right, so the higher i make the value the leaner it gets right. I just want to be able to adjust the fuel curves globally since that may be a little easier dealing with weather changes etc.
Originally Posted by sgplancer
Wish I'd thought of that....
Originally Posted by MalibuJack
I'm actually doing that.. but remember, modified injector size work with the open loop fueling, and stock injector size scales the MAF settings (for closed loop and idle)
I wanted to richen up my fuel table so I set my modified setting from 550 to 530
Sorry about that, just got your PM. I guess it worked out though. For the maps I posted, I have mine set at 550/550. Just some fyi.
