Which is the best Xede,Utec etc ?
I am somewhat confused by your question. If you are asking if the car's immobilizer protection is left in place, then the answer is yes. Unlike many other systems, the stock ECU is left untouched.
If that doesn't answer your question, please let me know.
Originally Posted by silvery_eagle
one other question i have in mind that bugged me so long about Xede is that once installed Xede, are we going to lose the immobilizer function?
From: Where you come to vacation and go home on probation! Vegas!
Originally Posted by shiv@vishnu
Does the f-con pro have a knock sensor?
shiv
shiv
Here is more info on the FCON
http://www.hksusa.com/categories/more.asp?id=1933
shiv
shiv
I just installed the Xede, and it was definitely worth it. The installation was a breeze, it took me all of 45 minutes being super careful. I ran into an issue where I was trying to run it before the map was loaded, but I called Vishnu, and Shiv hooked me up. He e-mailed me the map I needed for my car's setup (Turbo-back cat-less exhaust & 93 octane), and then he walked me through the upload process which took all of 20 seconds to do. (As long as you have a laptop.) The difference in power is very noticeable. Vishnu and the Xede are both awesome!
