Lets see your fuel maps w/cams
Old Mar 16, 2005 | 06:46 AM
dryad001's Avatar
Preferably with stock injectors. Just looking at mine and a friends map and see how much they differ from others.
Old Mar 16, 2005 | 07:07 AM
sgplancer's Avatar
Well I am running 700cc injectors, but here is a link to my setup:
https://www.evolutionm.net/forums/sh...d.php?t=115473
This has all of my information.
Old Mar 16, 2005 | 11:03 AM
superman105's Avatar
Old Mar 16, 2005 | 11:12 AM
bump
Old Mar 16, 2005 | 11:23 AM
sgplancer's Avatar
Originally Posted by superman105
we swapped UTEC with each other and use the same map
A/F ratio came out different with different UTEC
both running 1.7 the same way with same map
1 UTEC produce 10.8 - 11 A/F ratio and the 2nd UTEC came out 12-12.5 A/F !
I find this disturbing and a little hard to believe. I am not saying it isn't true, but damn, same maps produced different af ratios on the same car, but just different UTECs? I say WTF?!?!
I have a friend here in Houston that was running the same mods as me, and produced decent af ratios based on my map. Two different UTECs, cars, and color ( ), but the af ratios were semi-close. He was only using it as a base, and has tuned from there.
All in all, you shouldn't use another persons map for sole use purpose, but I would use one as a reference to see where the curves are. This is just me, and my .02 only.
Old Mar 16, 2005 | 11:24 AM
sgplancer's Avatar
^ sorry , but I had to state my case. BOT....
Old Mar 16, 2005 | 11:50 AM
bump
Old Mar 16, 2005 | 11:55 AM
bump
Old Mar 16, 2005 | 10:06 PM
dryad001's Avatar
And I thought MJ would say this first. I am just trying to see if it is the climate, location, etc if they are all different. I will be doing a lot of road traveling this year and just trying to get a feel for everything. And yes I do know that there is 93 and 91 states out there. All I am trying to do is create somewhat of a standard.
Old Mar 17, 2005 | 09:08 AM
I took my post out
because I dont want any troubles
what I wrote was 100% fact
see for yourself and good luck
