what a/f are you guys at?
Definitely add a bit of fuel.. I run 12.5 on my race tune, definitely dangerous and will damage parts eventually.. 11.5 is about the leanest I would go on pump gas, 11.0 on 91 octane.. Alot of this is also dependent on your timing since there is an interrelationship there.. But you should be either turning down your boost to 20psi, or adding fuel across the board until you hit 11.0-11.5
Originally Posted by gestalt
15:1 and you will grenade your engine in no time flat.
For a conservative tune, you should target about 11.2:1. at WOT. Post some logs and I am sure that you will get some more help.
as the RPMS go up then more full is added
Here's a mildly-related question...
I have targeted 11.2-11.3 on my street tune. But I've been thinking that in the lower load sites, maybe it could be a bit leaner?
I looked at my old logs when my car was stock, and it looks like the AFR's taper from about 13.5 at 10%, to 12.2 @ 20%, then 11.5 from 30% to 60%, and 11.0 from 70% on.
So my question is, what is everyone doing with their AFR's in the lower load sites, say 10 to 30%? Are you targeting the same AFR across the board and adding timing to compensate? If not, what AFR are you shooting for in the lower loads?
Here's what I was thinking:
10% 13.5
20% 12.5
30% 12.0
40-60% 11.5
70%+ 11.3
Sorry for the thread hijack, but Luke WL may get some help from this also.
10% 13.5
20% 12.5
30% 12.0
40-60% 11.5
70%+ 11.3
You have a good point.. When your at peak boost, you want to keep it rich enough so you don't do damage, even lower boost levels you want to maintain a fairly rich AFR.. At low load sites, you can run leaner and will get much better gas mileage and part throttle drivability (it won't feel muddy when it transitions into open loop) when I cross over from closed loop to open loop, I go from 14.7 (closed oop) to 13.5 then as it hits the higher load sites it quickly goes richer.
So is there an easy way to add fuel all accross the board? Because Im running about 14.8 on partial throttle cruizing speed... or do I have to go in and add fuel at individual levels....how would I do this?
Get the UCC program, I'll try and find the link.
EDIT: Here's the link:
http://norcalevo.net/ucc/ucc-current.zip
Just save it and install. Personally it's easier to use and see during tuning but I don't think you can change the parameters like TPS threshold, inj scaling and whatnot.
Hopefully this helps
EXT Load Knock Mod Mod Mod
RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF
psia Hz % deg duty deg % (OL) Hz
876 +25.7 30 0 00 00 +3.2 1.1 ECU. +0.0 ECU. 29
877 +25.7 30 0 00 00 +3.2 1.7 ECU. +0.0 ECU. 30
886 +25.7 30 0 00 00 +2.1 1.7 ECU. +0.0 ECU. 29
881 +25.7 30 0 00 00 +3.2 1.1 ECU. +0.0 ECU. 31
878 +25.7 30 0 00 00 +5.0 1.6 ECU. +0.0 ECU. 29
868 +25.7 29 0 00 00 +3.2 1.6 ECU. +0.0 ECU. 30
874 +25.7 29 0 00 00 +3.2 1.7 ECU. +0.0 ECU. 29
3168 +25.5 220 20 00 00 +33.8 9.9 ECU. +0.0 ECU. 223
3217 +25.5 216 20 00 00 +32.7 8.2 ECU. +0.0 ECU. 258
3217 +25.5 217 20 00 00 +33.8 10.5 ECU. +0.0 ECU. 235
3267 +25.1 215 19 00 00 +34.5 8.0 ECU. +0.0 ECU. 207
3293 +25.3 400 30 00 00 +23.6 ---.- ECU. +0.0 ECU. 447
3397 +25.5 515 54 10 00 +16.6 23.0 +12.8 +0.0 75.00 595
3432 +25.3 610 66 10 00 +11.7 25.6 +12.8 +0.0 75.00 809
3516 +25.7 787 74 10 00 +6.9 32.0 +12.8 +0.0 75.00 853
3654 +25.7 912 78 10 00 +4.5 39.2 +12.7 +0.0 75.00 976
3805 +25.5 948 83 20 00 +3.5 42.8 +9.9 +0.0 75.00 1050
3935 +25.5 924 85 30 00 +4.1 42.4 +9.8 +0.0 75.00 1168
4100 +25.1 954 87 30 00 +5.1 46.2 +10.1 +0.0 75.00 1054
4268 +25.1 994 93 40 00 +5.4 46.6 +9.2 +0.0 75.00 936
4415 +25.5 1002 95 40 00 +6.5 46.7 +8.8 +0.0 75.00 1000
4553 +25.5 1075 98 40 00 +6.6 54.4 +8.5 +0.0 75.00 1059
4668 +25.7 1121 100 40 00 +6.6 56.6 +8.6 +0.0 75.00 1033
4852 +25.9 1152 100 40 00 +6.9 58.8 +8.3 +0.0 75.00 1256
5012 +25.9 1216 100 50 00 +7.1 59.7 +7.4 +0.0 75.00 1358
5282 +26.1 1329 100 60 00 +6.3 63.0 +8.2 +0.0 75.00 1237
5385 +25.7 1351 100 60 00 +6.0 64.5 +8.2 +0.0 75.00 1479
5546 +25.7 1366 100 60 00 +6.1 67.1 +8.6 +0.0 75.00 1282
5668 +25.5 1400 100 70 00 +7.0 68.3 +10.3 +0.0 75.00 1420
5787 +25.7 1432 100 70 00 +8.0 68.9 +11.8 +0.0 75.00 1420
5952 +25.5 1457 100 70 00 +9.1 70.6 +12.1 +0.0 75.00 1420
6082 +25.7 1483 100 70 00 +10.3 72.7 +12.6 +0.0 75.00 1436
6230 +25.7 1501 100 80 00 +11.2 73.6 +13.5 +0.0 75.00 1497
6325 +25.5 1519 100 80 00 +12.5 74.8 +14.4 +0.0 75.00 1445
6485 +25.7 1557 100 80 00 +13.4 76.2 +15.3 +0.0 75.00 1524
6561 +25.3 1547 100 80 00 +14.6 76.8 +15.8 +0.0 75.00 1497
6734 +25.7 1567 100 80 00 +15.8 77.8 +16.1 +0.0 75.00 1602
6816 +25.7 1587 100 80 00 +16.4 77.5 +16.2 +0.0 75.00 1666
6915 +25.9 1592 100 80 00 +17.4 78.7 +16.3 +0.0 75.00 1592
7032 +25.9 1623 83 90 00 +20.9 79.0 +16.6 +0.0 75.00 1515
heres one of the logs..any help> I got the Ucc, I just dont know where to put what numbers... im kind of lost with this thing.
btw, I dont have the knock sensor.... but the service engine soon light has flashed a few times...is there a stock knock sensor or do I have to get a new one with the utec?
Luke,
Post your mods to get better assistance. In addition, how do you know what your AFRs are? I didn't see a WB column in your log. The check engine light flashing is NOT a good thing. It is the UTEC telling you that you have knock. Look at your logs for knock and at least back down your timing in those map cells. If you have an AFR readout, check your AFRs and based on the result, add fuel if needed.
The utec dosent show any knock...
mods are
Perrin Intake
Walrbo 255
Turbo back catless
Utec (with stage 2 map)
Turbo XS wideband tuner
Turbo XS RBV bov
I dont have the knock sensor for the Utec or does it just use the stock one? That might be why it wasnt reading it. The wideband tuner is where I got my a/f .
mods are
Perrin Intake
Walrbo 255
Turbo back catless
Turbo XS RBV bov
To modify your map on UCC you need to download your map from the UTEC and then and fuel in the "fuel monitor" The is a way to select all colums and then hit the + and it will add .1 fuel to every box that was selected.
The logs you need is the ones that have the WBO2 reading
Edit: Do you have the switch installed? If not what map are you running.
