How to maximize power with Apexi AVC-R
Old Apr 25, 2005 | 08:41 AM
whiteEv0boy's Avatar
Hey guys any suggestions on the settings I should be running with the AVC-R?
Mods: Turbotrix flash, K/N cone air fliter.
Currently running at 1.4 bar with mixed duty.
Would like to have a high boost setting and a gas saver setting. Thanks.
Old Apr 25, 2005 | 12:33 PM
Widebandphillip's Avatar
turn it off. You have an a, b and off setting. use the off setting for gas mileage. that 1.4 bar could be your b setting and your race gas setting could be your a.
Old Apr 25, 2005 | 02:02 PM
EVIL MR's Avatar
What He Said^^^^^^^
Old Apr 25, 2005 | 03:03 PM
Whats the maximum psi/bar that I should set with the setup I have right now?
Old Apr 26, 2005 | 12:34 PM
Please post the settings on your AVC-R if you have time. Thanks
Old Apr 27, 2005 | 06:28 AM
Does anyone have issues setting up the AVC-R? When i set the cylinder to 4(recommended by Apexi) the RPM sensor malfunctions. It displays 230-270 rpm at idle, which is way off. Please post your settings thanks.
Old Sep 18, 2005 | 01:09 AM
Hyper_Rev's Avatar
Your settings should be Cyl = 4 / Spd = 4 & for Throttle the arrow should be pointing up. If that doesn't help check your wiring. Just trying to help.
axxevo8
Nov 22, 2015 08:20 AM
Mrauto50
Feb 23, 2012 05:38 PM
jcsbanks
12
Oct 29, 2007 01:21 PM
Kayaalp
Northeast Region
Jan 26, 2006 12:42 AM
Claudius
European Forum
20
Feb 13, 2002 10:31 PM
