Flash vs SAFC
Old Apr 30, 2005 | 08:19 AM
  #31
turbolarry's Avatar
Originally Posted by dsm95hybrid
With just the afc, how will you adjust timing? Raise rev limit? boost? increase spoolup? Remove top speed limiter? I ran a 12.42 on flash alone with other basic mods- no safc. Like I said I only run it now for meth injection to lean it out. I tried to improve over the flash and ended up zeroing back out as the flash was much better. Check out www.jestrtuning.com. He flashes under some of the biggest name companies out there.
Do you have a log of this flash?
How are you monitoring your adjustments to the AFC?
How do you raise your boost?
How often do you rev past 7600 RPM's and drive over 155mph?
Old Apr 30, 2005 | 08:38 AM
  #32
HxllxMan's Avatar
Flash + AFCII is a good combo if you want to switch from Gas pump to Race Gas.
Old May 1, 2005 | 12:30 PM
  #33
dsm95hybrid's Avatar
Well yes I do. Here are logs for before and after the JEstrFlash.
BEFORE THE JESTRFLASH
AFTER JESTRFLASH (missed 3rd gear, D'oh)
I don't quite understand you next question. The AFC is zero'd out on pump gas and only used for methanol injection.
The JEstrflash removes boost taper and increases the boost to maximum pump gas safe levels 20-22psi. This additional boost option was added after I already had a hallman so I currently use the MBC which is needed to adjust the boost higher for meth.
Rev past 7600? At least 8 times a week I bounce off the limiter in my short 2nd gear. The fastest Evo's use higher limits than that. There is another local with a 8300rpm limit that ran 11.6 on the stock turbo. He was also flashed with the JEstrflash. See the website for the details . Drive 155+?, never and no plans to do so in the near future.
Depends on what octane you use. The log below represents 110 octane and NO ADDITIONAL tuning! The higher octane richens it up and the additional boost leans it back out giving you a great tune with no need for an afc. I ran a 12.42 under this flash with 110.
JESTRFLASH on 110 and additional boost
With C16 an afc would help as you can lean the hell out of the tune on that fuel. For those with normal budget that refuse to dish out $60 for 5 gallons of c16, the 110 on the flash works well.
Old May 1, 2005 | 12:56 PM
  #34
turbolarry's Avatar
Thanks dsm95hybrid, but I was looking ignition timing improvements provided by flashes. Something like this;
http://www.evotuners.net/forums/showthread.php?t=299
Old May 1, 2005 | 01:51 PM
  #35
There are some timing tricks the flash tuner can talk to you about if you contact him. I know that my minimum start value has been raised, idle timing raised for the 272's, added fuel. There is a "no less than X*" of timing flashed in there. With that it is easier to pick up knock retard (knowing what # to look for). I will be increasing timing here in the next few days due to no knock on the WI. This is included in the available subscription service (6 months of updates)
Old May 1, 2005 | 03:15 PM
  #36
blueo4's Avatar
i just tell the dealer i am only using it for monitoring purposes and not tuning! works for me!
Old May 1, 2005 | 11:20 PM
  #37
turbolarry's Avatar
That's one thing I've been trying to see for a while now. Since March I've been trying to get a log of this from someone.
I was trying to tune an AFC on top of a flash and it was three times as hard. Despite any adjustments I made between 3000-5000 RPM's the timing would not move. I went lean here too, had to have been knocking lean, but the ECU would not pull timing like it should. The opposite wouldn't work either. No matter how rich I made it, the ECU wouldn't advance timing either.
If the timing doesn't move, how do you detect knock? Was this just a fluke flash? I'd love to know for sure.
http://www.evotuners.net/forums/showthread.php?t=364
Old May 2, 2005 | 06:06 AM
  #38
Not sure how someone else's timinng #'s would help you, but yes mine pulls timing upon knock just like a stock car.
Old May 2, 2005 | 07:18 PM
  #39
"What the ???? Cleaning out the MAF? What could possibly be in the MAF? Hope you did not touch the resistor in there. You can kill it easy that way."
you're thinking about the hotwire maf sensor. Karman works differently. You can easily kill the MAF sensor, period.
There could be dirt and oil in in the MAF sensor.
do some search or read my post that I've linked on how karman vortex sensor works and how the friction difference in the maf sensor surface to distort the votex, or even oil getting into the mirror.
I've read your thread:
I called the dealer, they told me there is 3 hot wire in my MAF sensor and I shouldn't clean it or even touch it. I don't see what the hell he's talking about, since I was looking at the Karman Vortex sensor diagram when I was talking to him.
All I saw was, photocoupler, mirror, pressure directing hole, intake temperature sensor.
I asked him, "are you sure you're not talking about the HOT WIRE sensor?" he's like, "evolutions have 3 hot wires inside the MAF sensor. Don't touch those.".
I never said is was a hotwire (GM type) airflow sensor. The 4g63 has always used the karman vortex meter.
The pic in your other thread shows the "resistor" I warned you not to touch. IAT sensor/resistor the point was it can kill the meter. Unfortunately I am speaking from experience because my Mercedes maf died that way. Take it for what it is worth. Sure you would rather spend $450 on IC pipes than a new MAF.
Old May 2, 2005 | 07:43 PM
  #40
plokivos's Avatar
I believe that "resistor" is actually the intake temp sensor. and no, i didn't touch that thing. Just touch the pressure sensor pipe.
i rather spend that $450 on getting a set of seperate race tires.
