UTEC Serial Cable help
Old May 5, 2005 | 05:51 PM
D Town WRX's Avatar
I bought a used utec and it didnt come with the serial cable. I bought one it didnt work with the utec so I had to borrow my buddies wrx cable from his utec. Does anyone know the exact specs for the cable I need length and everything if so please help. thanks
Old May 5, 2005 | 06:13 PM
MalibuJack's Avatar
its just a regular 9pin M - 9pin F cable.. same type of cable you would use to connect a modem...
Old May 6, 2005 | 05:16 AM
EvoTech's Avatar
I have an extra if you need it. Just hit me up with a PM.
Old May 6, 2005 | 08:48 AM
PDXEvo's Avatar
Or just go to Office depot and get a Null Modem cable.
Old May 6, 2005 | 09:30 AM
MalibuJack's Avatar
This is incorrect.. Its not a null modem cable... ITs just basically a modem/PDA extension cable.. 9pin din Male, to 9pin din female..
A nullmodem cable will not work at all..
Old May 6, 2005 | 09:36 AM
dryad001's Avatar
I think I have a few extras around the house, I'll run outside and see if they work with the UTEC. BRB.
Old May 6, 2005 | 09:43 AM
D Town WRX's Avatar
thanks for the help guys I really appreciate it.
gestalt= I sent you a pm about that extra cable you have.
Old May 6, 2005 | 01:07 PM
PDXEvo's Avatar
I am using a Null Modem cable just fine. Its a DB9 cable that says NULL MODEM on the ends of the cable.
Old May 6, 2005 | 01:25 PM
MalibuJack's Avatar
It isnt wired as a null modem then.. a null modem cable is used to connect two computers together.. usually its a DB9F to DB9F.. The cable he needs is just a run of the mill 9 pin cable.. you were lucky because either your cable is correct regardless, or the serial interface your using recognizes it.. (there are some rare USB to Serial adapters which can do it)
tscompusa
Nov 5, 2015 05:24 AM
BlueDevilWRX
Feb 1, 2011 09:48 PM
hearnoevo
Sep 14, 2010 08:15 AM
mfr122887
13
Apr 16, 2008 04:08 PM
Evo478
Jun 23, 2006 03:15 PM
