self learning throttle?
Old May 26, 2005 | 07:12 AM
sillypuddy's Avatar
I am going through the initial setup of the SAFC II and it says that I need to do the "throttle self learning" sequence
It's not quite clear on how or where to do this
do I set the cylinders, set the arrow (up) and then wait 10 seconds for the fully closed position and then hold the acceleator for 10 seconds fully open? does it give me an indication that it's done the self learning? (like beep or something?)
-joe
Old May 26, 2005 | 10:35 AM
turbolarry's Avatar
From the main menu screen select "etc," then "car select."
Under "cyl," select 4.
Under "thr," turn the arrow up.
Just count to ten and it should be fine. If it's not done, you can't select low throttle settings or monitor throttle.
Old May 26, 2005 | 10:45 AM
sillypuddy's Avatar
thanks turbolarry
-joe
harp12
Nov 3, 2014 07:45 PM
alsong2002
Mitsubishi TC-SST Discussion
Sep 4, 2014 02:13 PM
J!n K@z@mA
Oct 13, 2013 10:38 AM
martymil
Apr 15, 2011 05:56 PM
Noogles
Jan 1, 2007 12:40 PM
