CEL fix for test pipe...
Old May 27, 2005 | 02:03 PM
chills's Avatar
If I install a test pipe will the UTEC be able to stop the CEL light do to the test pipe? I read the UTEC manual and it looked to have an option to turn off the CEL light, but that seemed to be permanent... meaning if there was an actual issue with the engine the CEL would not come on.. Is this correct?
If so, which would be better or easier to install. The Perrin electrical CEL fix or the spark plug defowler fix?
I should be getting my downpipe next week some time. I will be running Buschur 3" downpipe to test pipe to Buschur 3" cat back...
Thanks for you time.
Old May 27, 2005 | 02:16 PM
Turbolover's Avatar
I used the perrin cel fix. Super easy install and works GGGGRRREEEAAAATTT!!!!
?'s PM
Old May 27, 2005 | 02:28 PM
Thegame's Avatar
I'd try the spark plug non foulers first. That way you won't have to hack into any wires if you don't need to. Only use the simulator if that doesn't work.
Old May 27, 2005 | 02:36 PM
dryad001's Avatar
Yup, same thing i do and it works great. Just rmember to get the 18mm anti fouler and drill the center to 1/2 inch.
Old May 27, 2005 | 02:38 PM
chills's Avatar
I'm guessing I should get one of these fixes before I install my test pipe?
Old May 28, 2005 | 05:46 AM
MalibuJack's Avatar
Yes, if you expect to have a problem with a CEL due to the rear O2 sensor, the correct fix (besides running a "Correct" catalytic converter) is to use an electronic CEL fix, I do like buschur's mechanical CEL fix however if we know its there, I'm certain that the "Emissions inspectors" know what to look for too (assuming the lack of a catalytic converter wasn't obvious enough)
Old May 28, 2005 | 05:30 PM
chills's Avatar
I just got a spark plug non fouler... now just waiting for my downpipe to show.. should be here on Wed... I will be doing the install next weekend.. can't wait...
few more things to buy, then I will get the UTEC installed and tuned.. can't wait.. I hate seeing my new UTEC just sitting in it's box... hahahahha
Old May 31, 2005 | 09:40 PM
Bexa20's Avatar
I don't have the UTEC but I have TB exhaust and I cannot find a way to get rid of the cel light. I tried the spark plug antifoulers as well as the O2 simulators from Buschur, sadly none of the options work. I'm still fighting the issue and waiting for more suggestions to follow to get rid of the light. Here are the threads that I started to eliminate the sucker, anyone knows the answer to my question let me know.
https://www.evolutionm.net/forums/sh...d.php?t=138850
https://www.evolutionm.net/forums/sh...d.php?t=118050
Old May 31, 2005 | 09:47 PM
cyberninja's Avatar
I've had the fouler for the past several months and i'm running a s-afc2 and had no problems at all. My 2 cents
Old Jun 1, 2005 | 05:33 AM
krafty's Avatar
Or just get a Ultimate Racing test pipe and not worry about it. They have a built in fix and guarantee no CEL.
Old Jun 1, 2005 | 11:21 AM
chills's Avatar
I'll find out this weekend... my Buschur DP is being delivered today.. and this weekend I will be installing that with my test pipe... and I will be trying the mechanical fix first... so.. we'll see... I figured it was cheap and easy to try that first...
Old Jun 1, 2005 | 10:14 PM
ICE888's Avatar
I would do an electronic fix. I tried the anti-fouler fix, and initially it worked but after some tuning and playing around with the A/F's with the UTEC, they o2 sensor code came back on.
And if you turn off the cel with the UTEC, you are just telling UTEC to NOT show it on your cluster, but it will always be there until you clear it with a scanner.
Alfred
painstylez
Nov 17, 2012 12:41 PM
luvboost
Apr 14, 2011 11:23 AM
ev0lution9
Northeast Region
Mar 17, 2009 04:24 PM
koffebean00
19
Mar 6, 2007 05:33 PM
Trustz
Jul 9, 2003 05:06 PM
