My "professional" tune!?
Old Jun 7, 2005 | 07:30 PM
  #46
MalibuJack's Avatar
Wow, is that right? your car idles at 53hz?
I see where you got some knock, definitely a huge jump in timing.. hehe..
Old Jun 7, 2005 | 08:51 PM
  #47
Evoisdream's Avatar
these are for u jack!
injectors scaled to 720
no A/f changed at all
File Type: txt
File Type: txt
File Type: txt
Old Jun 7, 2005 | 09:00 PM
  #48
Evoisdream's Avatar
well with those the a/f is almost on im Knocking a LOT more with these though.....
Old Jun 8, 2005 | 06:03 PM
  #49
Evoisdream's Avatar
log home with turboxs timing map and blank fuel map
File Type: txt
File Type: txt
Old Jun 10, 2005 | 10:11 AM
  #50
Dieman's Avatar
Please remember to set up your TPS and double check the knock threshold on the car before you do anymore tuning. The UTEC's are a good system when set-up right but I'm always having to change the settings on a lot of the constants before I can start tuning a car. Just something to think about before you get too indepth with your EVO tuning.
Old Jun 10, 2005 | 01:43 PM
  #51
303Villain's Avatar
whats with the 37 and 16 counts of knock? looks like its getting better...way better than 9:1. good luck
Old Jun 10, 2005 | 01:48 PM
  #52
Evoisdream's Avatar
thanks guys should b fine tuning tonight so we will c
Old Jun 11, 2005 | 12:46 AM
  #53
Evoisdream's Avatar
welp gents just got back from wyoming its 1:45 in the AM and im officially tunned like a ****! justin is the man thats all i can say ill post up some sheets etc 2marrow thanks to my boy justdsm!
Old Jun 12, 2005 | 11:13 AM
  #54
Evoisdream's Avatar
so looking over all the logs and such looks like we made about 40hp or close 2 and about 10fl lbs using the data log lab as a guide. justin also looked over the logs and did some math looks like we took .5 to .6 of a sec off my 3rd gear pull ill post some stuff here soon still working on the fuel trims and getting those sorted out
Old Jun 14, 2005 | 09:48 PM
  #55
Evoisdream's Avatar
wondering which map looks better im gonna go to the track and run 2marrow..
File Type: txt
File Type: txt
Old Jun 14, 2005 | 11:18 PM
  #56
Widebandphillip's Avatar
lol those injectors are barely huffing and puffing. Afr needs to be a little richer around peak boost for my taste. Good call on backing off the timing on the top end. 880's sure do add a lot of timing. Good tune overall. Hell of a lot better than what you had before that i'm certain of. How's the idle with 880's?
Old Jun 14, 2005 | 11:32 PM
  #57
Evoisdream's Avatar
actuall the car runs and idles amazing u think the rich 9 or 11 is a better tune? wondering which one to run for the track 2marrow
Old Jun 15, 2005 | 12:35 AM
  #58
i'd go 11.
Old Jun 15, 2005 | 03:56 AM
  #59
EVO8LTW's Avatar
Looks like 11 is richer with more timing and 9 is leaner with less timing. Do you have time to try both maps at the track?
Old Jun 15, 2005 | 06:02 AM
  #60
JustDSM's Avatar
Hmm.
