S-AFC II settings?
S-AFC II settings?
For those fimiliar with Buschur Racing upgrade stages for the EVO. l am running a S-AFC II, along with a Buschur Racing intake, Buschur 3" TBE exhaust, and Hallman manual boost controller. My S-AFC is set with Buschur racing settings. The settings say that they a geared towards the specific parts I just listed, but I read a post sometime ago that said those settings are good through the second or third stage I believe. Can anyone confirm this?
Originally Posted by sccavee
Should still be the same, until you add in cams. I would also get a wideband to see where you are really at. I changed my setting from the BR setting once I had a wideband.
how much of a change did you make?
Originally Posted by yokomo
did you go more richer or leaner?
Claudius
May 10, 2006 06:41 PM
Thunder-rush
May 25, 2005 03:38 PM
