question about cams Again
Old Jun 28, 2005 | 04:36 PM
SilverMr's Avatar
Was wanting to know how people with the 272 in and 264 ex like the set up.I've read all kinds if cam threads about 264in-264ex,264in-272ex,272in-272ex.The thing is is that I'm looking for the best set-up using stock turbo or maybe White Rabbit for a good autocross set-up.I've been told that the 264-264 set-up is good for tq but the topend is weak and the 272-272 set-up is good for topend but not a lot of tq.i dont know about the 264in-272ex.I was just told yesterday by logicperformance that the hot set-up is the 272in and 264ex.My supporting mods will be 3'tbe with random tech hfc.Ported exhaust manifold.New 02 housing.Works drop in filter and jdm bov.and a tune once everything is installed.I'm not looking to be the fastest evo.I just want more power with a good powerband throughout the rev range.
Any help would be appreciated.
Thanks
Old Jun 30, 2005 | 07:53 AM
Ludikraut's Avatar
I don't believe in mixing and matching different cams. If you have adjustable cam-gears, you should be able to achieve close to the same results by adjusting them accordingly. If you haven't seen it, check out TedB's cam timing thread.
l8r)
Old Jun 30, 2005 | 05:56 PM
SilverMr's Avatar
Thank You for help and the link
Old Jun 30, 2005 | 06:09 PM
Toddevo 8's Avatar
I had the 272-272 combo and like it alot. but with the new turbo I will be adding the 280 cams.
evobullit2017
46
Jul 21, 2010 05:03 AM
s10v8
Nov 4, 2007 03:52 PM
livesports
Dec 2, 2004 08:54 AM
titaniumkingpin
11
Nov 29, 2004 01:43 AM
Gruppe-S
Sep 26, 2004 11:49 PM
