MDP sensor and Power FC on Aussie EVO 8
Old Jul 18, 2005 | 04:51 PM
Adrock's Avatar
Hi Guys!
Just wondering what role the MDP sensor plays on a power FC? Is it critical?
My reason for asking is I have an EVO 8 (I believe it is a EURO Spec model) I am trying run a Power FC on (Apexi Part number 414-M907) . It all seems to work fine however the engine checklight is on and my FC Commander highlights the MDP sensors as a Fault.
Upon futher investigation, I have discovered that the pin on the ECU where the MDP signal wire should go in (Pin 73 - if I recall correctly) is vacant.
Is it possible that this EVO does not have an MDP sensor, and if so can I run without it - and perhaps get rid of the fault by "piggy backing" a signal from another sensor?
I would be most grateful for any suggestions
Regards
Steve
Old Jul 18, 2005 | 05:24 PM
Karash's Avatar
side question, what is the MDP sensor?
Old Jul 19, 2005 | 05:48 PM
gvr4v's Avatar
Steve,
If your EVO is a Euro spec, then probably does not have a MDP (manifold differentail pressure) sensor. Look on your intake manifold to the left side before the fuel pressure regulator. It should be there if you have one. If not, that is why your check enigne light is on. I had the same problem with mine. We had it tuned with out it, then when we did finally get it installed, we had to change the fuel map greatly. The pin #73 is vacant so you will have to wire a mdp in. We just used a unit from a US EVO8 and wired it into the ecu. I made a adapter for the mdp and ran a vacuum line to it. I can post some pics for you if you like.
Thanks, Victor
Old Jul 19, 2005 | 10:10 PM
Adrock's Avatar
I see...
Hi Victor,
Many thanks for your reply! I am entertaining thoughts of wiring 5v Map sensor into the pin just to extinguish the light. What do you think?
The fitting of a factory MDP Sensor sounds like the ideal situation - but I will have trouble getting one of those me thinks.
None the less I would be greatly interested to see ho youy have done yours, if it is not to much trouble I would love to see some pics. You wouldn't happen to have turned up a pinout diagram for a Euro spec ECU by anychance...?
Just curious as to what the exact role is of the MDP sensor? Altitude compensation? Emmisions? (I am so just guessing here - if you haven't figured it allready - I am not a tuner - just a bloke who is trying to make his power FC work properly.)
Thanks for your input - would be lost without helpful guys like yourself!
Regards
Steve
Old Jul 20, 2005 | 03:34 AM
gvr4v's Avatar
Steve,
I will send you some pics and the install I did on mine this weekend. I'm not exactly sure what role the MDP plays, buy when we tuned the car with out it, it ran great. When we installed the MDP, it ran very rich.So we had to re-tune it. I would use the factory MDP since you will not have to do anything but connect it.
Thanks, Victor
Old Jul 30, 2005 | 10:22 PM
Targa Tom's Avatar
Do your self a favour
Originally Posted by Adrock
Hi Victor,
Regards
Steve
You are running an EVO VIII and you are going to bodge a sensor to trip a dash light? If the engine when fitted ran rich it is obvious there is a factor attached to the map via this sensor.
Work on the principal someone at the three diamonds thought their car needed one.. maybe for Californian emissions, dunno.. but the hard work is done. Parts are available, a bloke will send you pics and has told you what to expect when you fit it.
That way you wont **** a 60k motor car trying to save 100 bucks.
IMHO
TT832
Old Jul 31, 2005 | 02:19 PM
Guru's Avatar
The MDP code is nothing odd. If you have D-Jetro model, it really doesn't matter and will not affect anything except for the CEL being on. Simply wire in the Map sensor off an EVO VIII and call it good. You do not have to hook up vacuum to it since it will read off the Apexi 3 bar map sensor anyway. The ECU just wants to see it there for some reason. Kind of odd if you ask me since it isn't being used.
Old Jul 31, 2005 | 04:24 PM
BADEVO's Avatar
IMHO
TT832
Um, He's NOT running an VIII ......
Old Sep 17, 2005 | 05:57 PM
Targa Tom's Avatar
Sorry my mistake....
I thought "My reason for asking is I have an EVO 8 (I believe it is a EURO Spec model) I am trying run a Power FC " meant he had an EVO VIII.
Ah well you live and learn.
TT
MegaTek29
Apr 29, 2013 09:51 PM
Ceddy
Apr 24, 2010 07:29 AM
Danieln
Dec 12, 2009 03:00 PM
evoredy
Feb 7, 2009 05:38 AM
Appauldd
Jan 26, 2009 07:57 AM
