Turboback install??
Old Jul 21, 2005 | 05:29 PM
phenominalpinoy's Avatar
Turboback install??
ive had my evo for a while now and just decided to mod it. im about to install a turbo back exhaust and was just wondering if there was anything else i needed to make sure everything runs smoothly. should i expect a CEL after this install and if so which CEL eliminator should i go with? sorry if this is noobie-ish...thanks
Old Jul 21, 2005 | 05:52 PM
joaquin654's Avatar
Talking From my own experience...
ok , here it is ... installing a Turbo back exhaust removes the Catalytic Converter , therefore the O2 sensor you have in the rear section of the exhaust will notice and throw a CEL .definitely consider getting the Perrin CEL elimanator or a mechanical CEL fix like the spark plug anti-fouler thing everyone has been talking about . if you don't plug the O2 sensor , you'll get a CEL , if you install the Turbo-back Exhaust without a CEL fix , you'll get a CEL . so some people i know get a downpipe , high flow cat , and cat-back exhaust instead of removing the cat to not need a CEL fix . oh yeah , i almost forgot that in most if not all 50 states , removing the cat is highly illegal .... so if you remove the cat , watch out for nosy cops with Evo-hatred .... hahaha .... i hope i was of some help ....
Old Jul 21, 2005 | 07:44 PM
i got a hf cat along with the rest of the exhaust so i should be ok right?
Old Jul 22, 2005 | 06:02 PM
joaquin654's Avatar
Talking
yeah , you SHOULD be ok .... but some HI-FLOW cats do trigger a CEL but never fear , gruppe-s now sells a mechanical fix for around 15.00 bucks .... you simply plug the O2 sensor into the fix and that into exhaust pipe and your done . now the O2 sensor is out the flow of the exhaust and will be " tricked " .... wish ya the best.
Old Jul 23, 2005 | 01:02 PM
gixxer9's Avatar
I was fine with my TBE and high flow cat for a few months, and then started getting the po420 code. I used an o2 simulator provided by my exhaust manufacturer when I called them, and the CEL is gone.
dannyz
31
Oct 18, 2010 07:20 AM
newbienco
Jun 27, 2010 09:31 AM
TrackDays
Aug 17, 2009 11:01 PM
chills
11
Jun 1, 2005 10:14 PM
Trustz
Jul 9, 2003 05:06 PM
