23 PSI at IDLE
Old Jul 26, 2005 | 06:51 PM
mike1023's Avatar
Exclamation 23 PSI at IDLE
I just installed my UTEC in my 05 EVO. For some reason I am seeing about 23 psi at idle. I just reflashed with 1.7 and have not changed anything.
I also tried changing the boost display from atmospheric to gauge but that just made it go to -.7 psi, even under boost it stayed at -.7 psi.
If it is of any importance i dont have the abc installed.
What is going on?
Find Attach File of the log i did so you can see what i mean
File Type: txt
Old Jul 26, 2005 | 08:52 PM
Widebandphillip's Avatar
If you don't have the map sensor installed, you're fine. That's normal. I'm betting you don't have the map sensor so just ignore it.
Old Jul 27, 2005 | 08:28 AM
mike1023's Avatar
i dont belive so thats what i was telling my friend maybe need a map sensor. but now what does that map sensor look like and go. and where can i buy one. if can help would be great.
Old Jul 27, 2005 | 08:35 AM
MalibuJack's Avatar
YOu'd know it if you had it, since you would have specifically had to order it and hook it up.. -23psi is normal if you don't have it installed.. its the 0v point for the calibration settings in the UTEC..
Old Jul 27, 2005 | 08:39 AM
mike1023's Avatar
ok is there anyway i can have where read the voltage to see what boost im making. i know i have a boost gauge but for tuning resones. and also im waiting for the new map sensor to come out. you know when that will be able to get. i dont want to spend 120$ today and then like in 3weeks the new one out. becasue i would then sell it for like 50$ if that. let me know thanks for all the help guys keep it coming.
Old Jul 27, 2005 | 09:02 AM
MalibuJack's Avatar
Don't worry about it for the time being, just wait for the sensor you want if thats the case.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
5LEEPERISAH23I
Sep 21, 2016 08:39 AM
blackmambe_evo7
Jul 4, 2016 04:26 AM
EriCS
Feb 17, 2012 08:05 AM
David Buschur
AEM EMS
27
Oct 27, 2005 06:34 PM
