Datalog a 03 and 05 evo
Old Jul 27, 2005 | 10:15 PM
SlowCar's Avatar
Anyone with a 05 Evo + UTEC care to share your datalog? Just want to see what is making the 05s quicker than the 03s.....is it the timing...AFR....boost...?
Old Jul 27, 2005 | 10:39 PM
Warrtalon's Avatar
It's the 10.5 hotside...boost is also higher from the factory, but that's not a factor once an MBC enters the equation. On the same boost, the 05 will make more power due to the larger hotside...
Old Jul 28, 2005 | 05:51 AM
MalibuJack's Avatar
The 05's definitely seem to have better top-end since the hotside keeps the boost from tapering as much as the 03 turbos do when you maintain higher boost through redline, its also slightly less restrictive.. You'll notice the spool is ever-so-slightly later on an 05, but peak torque is about the same, it can maintain that torque a little better in a broader curve, and then won't taper as much, resulting in higher HP numbers, but similar peak torque numbers.
Old Jul 28, 2005 | 06:25 AM
HoLeeRay's Avatar
actually, '05s spool slightly quicker as well...
i did several side-by-side comparo's with my buddy who has an '03 evo. just cop a 10.5 hotside and you're set.
Old Jul 28, 2005 | 07:32 AM
dryad001's Avatar
I have a log with the WR if you want to see that, it has a 10.5.
I just need to know how to post up the logs from the UCC
Old Jul 28, 2005 | 07:41 AM
SlowCar's Avatar
go to logger -> export utec file....to a text file.
then cut and paste .......
Code:
....paste here....
SlowCar's Avatar
oops
Old Jul 28, 2005 | 08:02 AM
dryad001's Avatar
I think this was a 4th gear pull:
2172 -32.0 279 100 10 00 +15.1 11.2 +15.6 -2.0 ECU. 264
2213 -31.8 288 100 10 00 +14.3 11.5 +15.6 -2.0 ECU. 329
2279 -31.6 305 100 10 00 +14.8 13.1 +15.6 -2.1 ECU. 331
2370 -31.4 325 100 10 00 +14.1 13.3 +15.6 -2.4 ECU. 297
2427 -31.2 333 100 10 00 +14.8 13.6 +15.6 -2.8 ECU. 361
2474 -30.8 348 100 10 00 +14.1 13.5 +15.6 -3.0 ECU. 350
2568 -30.3 366 100 10 00 +14.5 13.9 +15.6 -3.2 ECU. 384
2632 -30.1 406 100 10 00 +14.6 15.8 +15.6 -3.2 ECU. 316
2703 -29.7 421 100 10 00 +13.5 15.9 +15.6 -3.2 ECU. 337
2829 -29.3 461 100 10 00 +13.5 19.8 +15.4 -3.7 ECU. 465
2908 -28.7 487 100 10 00 +11.4 21.3 +15.1 -4.4 ECU. 500
3016 -27.7 570 100 10 00 +11.5 23.6 +14.7 -5.7 ECU. 642
3086 -26.9 598 100 10 00 +8.2 25.8 +13.8 -6.9 ECU. 483
3208 -25.7 653 100 10 00 +7.7 29.6 +13.0 -7.9 ECU. 447
3343 -24.0 740 100 10 00 +7.6 35.0 +12.7 -9.7 ECU. 493
3508 -22.6 889 100 10 00 +6.7 41.1 +13.1 -11.2 ECU. 654
3658 -20.4 1033 100 20 00 +0.2 46.4 +10.4 -14.2 ECU. 936
3831 -17.7 1149 100 20 00 +1.2 53.0 +10.5 -14.9 ECU. 929
4035 -15.7 1131 100 30 00 +2.7 52.2 +11.2 -16.3 ECU. 796
4187 -13.4 1250 100 30 00 +2.6 54.7 +10.8 -17.2 ECU. 1050
4432 -12.0 1243 100 40 00 +2.7 57.6 +10.3 -18.5 ECU. 1091
4591 -11.2 1333 100 40 00 +3.9 58.3 +10.0 -18.8 ECU. 1054
4748 -10.8 1377 100 40 00 +3.9 57.8 +10.7 -18.8 ECU. 880
4952 -11.0 1420 100 40 00 +3.8 63.1 +10.5 -19.5 ECU. 1250
5136 -11.2 1449 100 50 00 +3.8 64.9 +10.7 -19.6 ECU. 1201
5324 -11.6 1479 100 50 00 +4.6 69.0 +10.9 -20.0 ECU. 1190
5464 -11.8 1547 100 50 00 +5.1 70.3 +11.0 -20.6 ECU. 1250
5630 -12.0 1562 100 60 00 +7.3 69.6 +12.1 -21.4 ECU. 1302
5817 -12.2 1623 100 60 00 +8.3 69.9 +13.0 -23.0 ECU. 1282
5984 -12.4 1683 100 60 00 +10.6 70.8 +13.5 -25.5 ECU. 1269
6138 -12.6 1748 100 60 00 +11.9 74.6 +15.0 -25.5 ECU. 1351
6337 -12.6 1754 100 70 00 +13.8 74.4 +16.4 -25.5 ECU. 1308
6472 -12.6 1766 100 70 00 +15.0 71.3 +17.6 -25.5 ECU. 1315
6640 -13.0 1798 100 70 00 +16.0 74.8 +18.1 -25.5 ECU. 1351
6775 -13.0 1851 100 70 00 +17.5 76.7 +18.4 -25.5 ECU. 1373
6915 -13.0 1851 100 70 00 +19.2 76.9 +18.7 -25.5 ECU. 1381
7062 -13.4 1893 100 70 00 +20.4 79.7 +19.1 -25.5 ECU. 1420
7215 -13.4 1845 100 70 00 +20.5 78.2 +19.8 -25.5 ECU. 1461
7326 -13.6 1845 100 70 00 +20.8 77.1 +20.3 -25.5 ECU. 1453
7440 -13.6 1818 100 70 00 +20.9 76.0 +20.4 -25.5 ECU. 1420
Pay no attentoin to the MAP column as I didn't set it right its was running absolute and not in gauge mode. I only hit 70% because I had no clue on how much air this would suck so my MAF Hz cutoff was set to 2100. I believe this was the 3rd pull done after the turbo install, i have a lot more 60+ pulls in the UCC. I'll try and find the old 9.8 pulls also so someone can look at the ever so slight difference.
Found one: (MAP is still off)
2329 +1.4 306 100 10 +16.1 13.0+14.9 -0.3 ECU 279 169
2367 +2.2 332 100 10 +15.1 12.8+14.9 -0.4 ECU 297 170
2467 +2.8 355 100 10 +15.2 13.4+14.9 -1.0 ECU 312 171
2519 +3.4 377 100 10 +14.4 14.8+14.9 -1.2 ECU 357 172
2610 +4.2 424 100 10 +13.1 16.5+14.9 -1.2 ECU 372 173
2694 +5.1 451 100 10 +11.1 18.3+14.9 -1.2 ECU 368 174
2805 +6.1 499 100 10 +11.1 19.7+14.8 -1.3 ECU 578 175
2913 +7.1 554 100 10 +7.8 22.0+14.4 -2.0 ECU 686 176
2986 +8.3 646 100 10 +6.4 26.0+14.0 -2.8 ECU 716 177
3150+10.0 693 100 10 +5.4 30.6+13.4 -3.1 ECU 602 178
3242+11.4 818 100 10 +3.1 35.3+12.9 -3.3 ECU 853 179
3384+13.6 938 100 10 +0.2 42.2+12.7 -3.6 ECU1157 180
3580+16.1 1082 100 20 -5.8 54.0 +9.8 -3.9 ECU1101 181
3736+18.7 1141 100 30 -5.7 57.5 +8.8 -5.3 ECU 853 182
3907+21.6 1190 100 30 -3.9 58.8 +9.3 -5.0 ECU1173 183
4060+23.4 1190 100 40 -2.8 59.4 +9.2 -5.9 ECU1184 184
4257+24.2 1253 100 40 -2.5 59.8 +9.2 -7.8 ECU1152 185
4420+24.6 1272 100 40 -3.4 61.3 +8.3 -7.4 ECU1256 186
4604+24.6 1396 100 40 -2.3 65.7 +7.8 -8.0 ECU1288 187
4748+24.6 1420 100 40 -1.9 69.0 +8.6 -8.1 ECU1366 188
4916+24.4 1470 100 50 +0.1 70.0 +7.4 -8.9 ECU1445 189
5050+24.6 1533 100 50 +0.0 71.0 +7.6 -9.8 ECU1302 190
5184+24.6 1524 100 50 +0.1 76.6 +8.0 -9.8 ECU1302 191
5324+24.2 1582 100 60 -0.9 76.3 +8.3-10.2 ECU1470 192
5464+24.9 1650 100 60 -0.5 81.4 +8.3-10.7 ECU1506 193
5611+24.6 1661 100 60 +1.6 79.0 +8.8-11.3 ECU1373 194
5767+24.2 1650 100 60 +3.4 82.4+10.5-12.3 ECU1381 195
5868+24.2 1677 100 60 +3.6 83.7+11.0-12.8 ECU1524 196
6006+23.8 1724 100 70 +5.5 83.3+12.4-13.9 ECU1506 197
6105+23.6 1724 100 70 +6.6 85.2+12.9-14.3 ECU1572 198
6218+23.6 1724 100 70 +7.7 83.8+13.3-14.9 ECU1396 199
6361+23.4 1779 100 70 +9.8 84.8+14.5-14.9 ECU1461 200
This is not a very good comparison becuse the 9.8 was a 3rd gear with a horrible boost leak and an MBC and the 10.5 was done in 4th with no leaks and an HKS EBC. Notice the 3000 range in the 9.8 log, this is where you can really notice the leak. I'll try and get better ones as my friend still has the 9.8 on his car with UTEC so I'll try and log from his car and then switch to my car. We have almost similar mods the only difference is the IC, he uses perrin I have Rnr. Let me know.
Old Jul 28, 2005 | 08:04 AM
dryad001's Avatar
Code:
....paste here....
Thanks, I found an old one in my computer already in a txt file.
Old Jul 28, 2005 | 07:00 PM
SlowCar's Avatar
dryad001:your MAF signal is very stable, are you using the stock air box?
Old Jul 29, 2005 | 10:21 AM
dryad001's Avatar
No I'm not. I am using an AEM hard pipe with a SPW 3" filter. It works a lot better than the AEM filter.
Old Aug 23, 2005 | 02:42 PM
rraulston's Avatar
Dryad, ime looking at your datalog here. Look at how fast your boost goes up as compared to mine.....
Code:
Code:
 RPM	  MAP	  MAF
    	  psia	  Hz
819	-5.6	31
859	-5.6	33
821	-5.8	30
843	-5.8	29
857	-5.8	29
2121	-8.2	61
2116	-8.2	62
2244	-7.2	269
2214	-4.9	265
2250	-2.8	238
2256	-0.4	293
2354	1	277
2454	1.4	293
2511	1.9	341
2583	2.4	380
2675	2.9	386
2763	3.5	396
2815	4.2	437
2939	4.9	490
3013	5.5	536
3115	6.6	599
3233	7.5	838
3360	8.7	909
3486	10.4	749
3642	12.5	899
3835	15.1	1179
4011	17.7	1470
4208	20	1066
4374	21.4	1400
4547	21.7	1400
4721	21.6	1577
4945	21.2	1483
5151	21.4	1683
5291	21.7	1587
5464	21.9	1612
5640	21.9	1718
5827	21.2	1754
5973	20.9	1618
6127	20.2	1805
6289	20.2	1754
6435	20.5	1937
6561	20.2	1689
6706	20.3	1831
6830	19.8	1824
6988	19.5	1879
7107	19.3	1865
Old Aug 23, 2005 | 05:38 PM
dryad001's Avatar
Don't go off of the MAP column. It's not correct, I re-did the numbers and I was way off, those are close but read a bit high.
I use a HKS EVC V boost controller, I have the gain set a little on the high side so boost builds a little quicker now. I'll get some new logs soon, the car is completely different now. My peak timing was i think at 14.5 now I am up to 22 degrees still on pump gas and no alky and best of all no knock. If you want to see my timing map here ya go.
Timing Map
[-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100]
[-100] [15.5] [13.5] [13.3] [12.8] [11.3] [11.3] [11.3] [11.3] [11.3] [11.3]
[-100] [15.1] [12.1] [11.9] [11.4] [9.9] [9.9] [9.9] [9.9] [9.9] [9.9]
[-100] [14.1] [11.1] [10.9] [10.4] [8.9] [8.9] [8.9] [8.9] [8.9] [8.9]
[-100] [11.2] [11.1] [11] [10.8] [10.7] [10.6] [10.5] [10.3] [10.2] [10.1]
[-100] [12.4] [12.3] [12.1] [12] [11.8] [11.7] [11.6] [11.4] [11.3] [11.2]
[-100] [11.3] [11.2] [11] [10.9] [10.8] [10.7] [10.5] [10.4] [10.3] [10.2]
[-100] [9.8] [9.7] [9.6] [9.5] [9.4] [9.3] [9.2] [9.1] [9] [8.9]
[-100] [7] [6.9] [6.9] [6.8] [6.7] [6.6] [6.6] [6.5] [6.4] [6.4]
[-100] [4.6] [4.6] [4.5] [4.5] [4.4] [4.4] [4.3] [4.3] [4.2] [4.2]
[-100] [4.3] [4.3] [4.3] [4.2] [4.2] [4.1] [4.1] [4] [4] [4]
[-100] [4.7] [4.6] [4.6] [4.6] [4.5] [4.5] [4.4] [4.4] [4.3] [4.3]
[-100] [5.4] [5.4] [5.3] [5.2] [5.2] [5.1] [5.1] [5] [5] [4.9]
[-100] [6.1] [6] [6] [5.9] [5.8] [5.8] [5.7] [5.7] [5.6] [5.5]
[-100] [7.5] [7.5] [7.4] [7.3] [7.2] [7.1] [7.1] [7] [6.9] [6.8]
[-100] [7.7] [7.6] [7.6] [7.5] [7.4] [7.3] [7.2] [7.2] [7.1] [7]
[-100] [7.8] [7.7] [7.7] [7.6] [7.5] [7.4] [7.3] [7.3] [7.2] [7.1]
[-100] [8.2] [8.2] [8.1] [8] [7.9] [7.8] [7.7] [7.6] [7.6] [7.5]
[-100] [10] [9.9] [9.8] [9.7] [9.6] [9.5] [9.4] [9.3] [9.2] [9.1]
[-100] [11.2] [11.1] [11] [10.8] [10.7] [10.6] [10.5] [10.4] [10.2] [10.1]
[-100] [14.6] [14.4] [14.3] [14.1] [14] [13.8] [13.6] [13.5] [13.3] [13.2]
[-100] [17] [16.8] [16.6] [16.5] [16.3] [16.1] [15.9] [15.7] [15.5] [15.4]
[-100] [18.7] [18.5] [18.3] [18.1] [17.9] [17.7] [17.5] [17.3] [17.1] [16.9]
[-100] [22] [21.8] [21.6] [21.3] [21.1] [20.8] [20.6] [20.4] [20.1] [19.9]
[-100] [23.9] [23.6] [23.4] [23.1] [22.8] [22.6] [22.3] [22] [21.8] [21.5]
[-100] [24.3] [24] [23.7] [23.5] [23.2] [22.9] [22.7] [22.4] [22.1] [21.9]
The map is modified just about everyday so try to keep that in mind. This is the map from about 4 days ago. i log pretty much all the time on the way to work lots of straight roads. There is only knock in 5th gear but that only happens around 14-15psi at any rpm. I am still not sure about the 0% column on how to run my own timing so if someone can chime in here and give some pointers. I would post my fuel map but thats not much use to anyone.
Im guessing for my 0% load at any givin rpm is to log and see what the timing is and just kinda go from there, but since it is in the 0% column won't this run all of the time even at idle? Do most people run with the 0% in ecu mode?
Old Aug 23, 2005 | 08:37 PM
rraulston's Avatar
yea, ecu in 0% for me......
razorlab
Jun 9, 2011 11:58 PM
bbak11010
Feb 7, 2011 08:01 PM
EVO8LTW
Aug 30, 2007 02:30 PM
j8
Nov 16, 2005 05:46 AM
EVIL_EVO_VIII
Aug 21, 2005 10:42 PM
