Autronics autotune Vs. vishnu smart
Old Jul 31, 2005 | 08:57 PM
SlowCar's Avatar
I am trying to find out more about this 2 autotune systems. Would anyone with knowledge of these 2 please chime in!
Old Aug 1, 2005 | 07:46 PM
SlowCar's Avatar
bump
Old Aug 1, 2005 | 08:26 PM
Dyno4mance's Avatar
The autronic auto tune only auto tunes A/F ratios using a specific gas analyzer that interfaces with the CPU as I understand it...
The Vishnu Xede package has pro-active timing, fueling and boost..the Xede is currently the only system at this price point to be able to accomplish this..
Also the autronic system is a MAP based stand alone and the Xede is a interceptor type piggy back that retains the factory MAF sensor and all of the factory knock retard protection.
Hope this helps...
Old Aug 1, 2005 | 08:33 PM
asasin79's Avatar
doesn't the autronics use static maps like it'll tune in tune mode then burn that map and it's done. right?
Old Aug 2, 2005 | 06:50 AM
Dyno4mance's Avatar
Yes, That's what I said...Auto tuning is not active tuning
Old Aug 2, 2005 | 11:06 AM
Big Boost's Avatar
Sorry, little off topic, but what other EMS offer this capabilities? Motec or AEMS? I am doing research on different EMS systems and I thought only the Xede offered this.....
Old Aug 3, 2005 | 10:50 AM
Dustin@Vishnu's Avatar
The xede is the only EMS that offers the active timing, fuel and boost maps. No other EMS has the capability to accomplish such a thing.
Old Aug 21, 2005 | 07:10 AM
ninjadoc's Avatar
Can you convert to a MAP sensor rather than MAF or is that in the future with the XEDE?
Old Aug 21, 2005 | 11:02 AM
shiv@vishnu's Avatar
You can do it now. Just set-up a map that outputs a freq output based upon MAP voltage (via external MAP sensor) and RPM. Takes 10 seconds to do. The calibration of that table, however, will take an hour or so to get it to drive well.
Shiv
Old Aug 22, 2005 | 08:25 PM
BJai02's Avatar
How can it be done without intake temp sensor? Are you using something else to calculate the weather change? Or you simply let SMART adjust itself?
Shiv
Old Aug 22, 2005 | 09:16 PM
You can either allow SMART to adjust for itself with respect to knock and AFR, which it will do very well. Or you can instal a 0-5v air intake temp sensor in an unused input and set-up a table with RPM as the X-axis and Air temp as the Y-axis and do all your fuel/timing corrections through there. I prefer the first way, however.
Shiv
Dynojet_Research
Mar 7, 2010 09:40 AM
turboevo8
Sep 5, 2009 02:37 AM
housedj
10
Apr 19, 2006 12:25 AM
gunnerman
10
Oct 31, 2005 05:00 PM
turboevo8
Jun 7, 2005 12:04 AM
