Turning with the Wideband
Don't play aroudn with idle, the ecu will handle that and it should be at 14.7
I don't even have Ne-points below 3000. I'd set them up for top end(3500-7000). I'd tune all of that to 11.2-11.3.
Originally Posted by NapervilleEVO
can you give a brief description of what your afrs should do. something like this:
idle 14.7
1000-4000 i add some fuel, but should i be at 12-13?
4000-5500 12?
5500-6500 11?
6500-up 11.3?
i dont know where it should be exactly. thx.
idle 14.7
4000-5500 12?
5500-6500 11?
6500-up 11.3?
Yeah -- 2.5 hrs of playing around, testing all the hardware -- pump worked, water solenoid worked, standard injector was working ...we could even jumper start the whole system...turns out the relay is bad *sigh*. So heading out to Pepboys or Autozone to get a new one...and now for some reason, the 12 v source I plugged my LED and my Radar detector into is no longer working ...argh! Hopefully it's just the fuse...
