a little help with my timing
i don't understand why my timing curve only peaks at 15 at redline. my curve seems a little flat to me. my a/f ratio is on the conservative side as well. any help would be appreciated.
Originally Posted by Kronik
We are in the process of building a tester -- we should meet up sometime soon so we can figure this stuff out, eh?
Oh, you have alky...hmm. I don't know how to tune afr/timing with an alky system while using a flash+s-afc, so I have no idea.
ok here is a new log. i richened it up a little to see what effect it would have on my timing. didn't have much. the outside temp was 93 degrees at 47% humidity.
Well make sure it's spraying correctly too -- the other night we found out that mine was just dribbling out...not even making a mist. I'd check that before spending more money..
did another 3rd gear pull tonight with my boost turned down to 21psi. here is a log with alky spraying with little change in my timing. my a/f is 10.7 across the board. i can't figure out what the deal is.
