MPS_UTEClogger 2.3
Old Oct 3, 2005 | 06:58 AM
  #61
Nesiop's Avatar
Bump...
Old Oct 4, 2005 | 04:39 PM
  #62
jmussetter's Avatar
Sorry I havn't been around in awhile...
have you dealt with the PLX loggers yet?
No I havn't heard of this one.
Adding more WB types to the expanding list is an ongoing quest. I must tell you, though, that the TechEdge and Zeitronic's brands are already on the list to do, and have been long in the waiting mostly because of the amount of time required to add and test new WB types. But others will follow...
BTW, look for new ver. 2.5 on the download page within the next day or two hopefully...I'm testing it now.
-jason
Old Oct 4, 2005 | 05:20 PM
  #63
WarmPepsi's Avatar
dude, once again, you rock.
whats the major changes for the 2.5? autotime-stamp style file names, and single stroke log/close log? anything else?
again, you rock.
Old Oct 4, 2005 | 05:54 PM
  #64
Killboy's Avatar
Keep in mind that this is a donation-driven project for Jason, so if you want to give him some incentive to continue development, hit up his site and make a Paypal donation at the bottom of the page.
Old Oct 5, 2005 | 10:47 AM
  #65
jmussetter's Avatar
Exclamation New version 2.5 Released!
MPS_UTECLogger v.2.5 is now avail on the web.
New features include:
- Hotkeys for starting and stopping logs.
- Automatic logname generation to eliminate typing while driving...
- Audible knock warning!
- Time/Date stamps and comment stamp embedded to saved LogMaps.
- More Com Ports to select from.
- minor bug fixes...
-jason
Old Oct 5, 2005 | 11:26 AM
  #66
Nesiop's Avatar
If you could please check PLXDevices.com Gruppe-s is a big vendor of them. The units are pretty popular now. A lot of people use the M-300 series.
Old Oct 12, 2005 | 08:31 AM
  #67
Nesiop's Avatar
ttt
Old Oct 21, 2005 | 09:56 PM
  #68
alfredob1's Avatar
I don't have any of the supported O2 reading devices. I have the Zeitronix unit, it uses a Bosch wideband sensor. Is there a possibility than one of the supported devices will work with the Zt-2? I wouldn't mind trying it out so long as their won't be any sort of damage caused.
BTW, I was messing with the 2.5 version of the software testing the auto naming and one button start/stop logging features and noticed the file extension is wrong. It looks like they are comma separated value (.csv) files but the auto name feature is attaching a .cvs extension. Other than that everything looks good. Keep up the good work.
Old Oct 22, 2005 | 10:41 AM
  #69
BJai02's Avatar
In terms of format, I think it would be nice to add a column logging what ignition timing the stock ECU wants to run. It would help looking for possible knocks that the stock ECU detected and the UTEC didn't. A good tuning tool for ignition tuning and knock sensor sensitivity adjustment.
Old Nov 3, 2005 | 07:55 AM
  #70
Nesiop's Avatar
Bump for anything new? I felt like I got screwed fore buying the PLX wideband, cause it is such a pain to have to try and compare the log on the PLX unit with tps and rpms and then look at the UTEC log in order to tune.
Old Nov 10, 2005 | 11:28 AM
  #71
Nesiop's Avatar
Bump....
Old Nov 15, 2005 | 01:34 PM
  #72
Nez136's Avatar
So i just was reading a post where a dude said he can read lower than 11.0 on the AEM, i can't with this software, is this true or are they full of ****?
Old Nov 15, 2005 | 09:27 PM
  #73
BJai02's Avatar
It has nothing to do with this software. I know it displays lower than 11.0 with my LM-1 and this software.
Old Nov 16, 2005 | 11:25 AM
  #74
Nez136's Avatar
right i know this, but b/c you have to select what wideband your using does the AEM seletion only allow 11.0?
Old Dec 4, 2005 | 07:26 PM
  #75
jmussetter's Avatar
Everything in their manual indicates that the AEM guage only reads down to 11.0:1 and no lower.
However, I don't own and AEM and couldn't confirm this when I added this to the program. If you can connect to the AEM from HyperTerm and log AFR's lower than 11:1, then let me know and I will fix the issue in the logging program.
-jason
