utec map selector
Old Sep 24, 2005 | 05:52 PM
SOUTHSIDEITALIA's Avatar
utec map selector
Anyone have any pics of a custom install for the map selector switch?
Old Sep 24, 2005 | 06:33 PM
WarmPepsi's Avatar
custom?
i put mine under the dimmer switch thing, facing down, so that it can't get bumped easily, and no one will fiddle with it.
Old Sep 24, 2005 | 07:56 PM
MalibuJack's Avatar
At least yours is mounted somewhere, I always intended to put it in the center console near the intercooler sprayer switch, since I'm replacing the sprayer switch with a arm switch for the alky kit. However at the moment I have it wedged between my seat and center console out of the way.
Old Sep 24, 2005 | 08:31 PM
EVO8LTW's Avatar
On my RS there is a blank on the dash next to the interior lights dimmer switch (I think it's where the headlight up/down adjustment is on a GSR or MR), so I put the map switch there and it blends right in.
Old Sep 25, 2005 | 03:01 AM
NocturnalEVO's Avatar
anybody got a pic of theirs?
Old Sep 25, 2005 | 03:08 AM
CoolGuyWes's Avatar
I would like to see pics too... I plan on buying that next
Old Sep 25, 2005 | 06:07 PM
BMan's Avatar
I originally put mine in the dash light adjuster location, but it was hard to see the map number so I moved it to the center console next to the IC sprayer switch. It is much easier to see and reach, however, sometimes I will hit the switch when using the cup holder. I'm looking for a new location now.
Old Sep 25, 2005 | 09:52 PM
joeymia's Avatar
Since my intercooler sprayer was gone I tore the swith out. Then got a dremel and made the hole a little bigger and got the switch in there. Looks stock there, the only problem I have is changing maps by mistake. I am going to place a little plastic cover over it and wire LED so I read the numbers at night.
Old Sep 25, 2005 | 10:02 PM
anybody have a pic of what the switch looks like? I haven't received my UTEC yet, and i'd like to figure out a place suitable to put the switch.
Old Sep 25, 2005 | 10:10 PM
joeymia's Avatar
Its not that big. If you have a intercooler sprayer it will be almost the same size as the toggle switch used to activate it.
Old Sep 26, 2005 | 05:23 PM
EvoTech's Avatar
You can see mine in this thread.
https://www.evolutionm.net/forums/sh...d.php?t=123260
Old Sep 26, 2005 | 06:03 PM
SubiEvolved's Avatar
i put myne where the IC sprayer switch is.
ERIK
mfr122887
13
Apr 16, 2008 04:08 PM
mfr122887
16
Nov 1, 2007 05:05 PM
TKEVO
Sep 25, 2007 06:32 AM
bishiboy
11
Dec 7, 2005 12:53 PM
justrick
Jun 3, 2005 06:25 PM
