Is my UTEC strange?
Old Sep 30, 2005 | 04:32 PM
joeymia's Avatar
Is my UTEC strange?
I am removing 10 points of fuel by redline to get my car at around 11.2 afr. I have also removed fuel in pretty much every cell. I have looked at some of the maps people post and have yet to see someone remove as much fuel as me. On my meth map I have removed like 15 points and I am still not in the 11's... Is this normal or is my car just odd.
Old Sep 30, 2005 | 05:10 PM
WarmPepsi's Avatar
hrm, with my injen intake/fmic, and the pump (3" turboback too), i'm at 11.2 with turboxs's stock map.
not meanin to go too far OT, but how do you like the 280's?
Old Sep 30, 2005 | 05:22 PM
joeymia's Avatar
i love them. Most people run lean on UTEC but I have to remove a ton of fuel to run right... I guess I am just odd.
Old Sep 30, 2005 | 05:24 PM
WarmPepsi's Avatar
well, the cams might be aiding that fact, but shouldn't. I'll probably catch ya at a meet, might even have seen ya at the import event day at moroso, who knows, would like to hear/see how they are
Old Sep 30, 2005 | 06:07 PM
BJai02's Avatar
Just make sure your WB sensor is calibrated correctly. Don't worry about how others' map looks like as long as you have your AFR checked. FYI, I removed about 9 points of fuel...
Old Sep 30, 2005 | 06:16 PM
midwestmonster's Avatar
Are you tuning your car yourself?
Old Sep 30, 2005 | 07:26 PM
dryad001's Avatar
I remove about 30% fuel but I am using 780's
Old Sep 30, 2005 | 07:35 PM
joeymia's Avatar
yes i am tuning my own car. I also have calibrated my wideband twice. When I am cruising the car is at 14.7 (stoich) so If it wasn't calibrated correctly I guess wouldn't be seeing stoich.
Old Sep 30, 2005 | 08:35 PM
SoR's Avatar
SoR
When I had an aftermarket intake I had to add tons of fuel while everyone was running rich. All in all, every car is different, and like bjai said, make sure your wideband is sane
Old Oct 1, 2005 | 12:06 AM
joeymia's Avatar
well i guess what matters how good the car is running. no knock and its pulling hard... I am getting over 2100 on the MAF by redline, no knock, and afr is sitting at low 11's. I was getting hesitation in the lower load cells and rpm because I had been so rich. I figured since car had to be so lean up top the same was happening in every cell. I removed fuel everywhere and the car is running so much better.
Old Oct 1, 2005 | 12:51 AM
Widebandphillip's Avatar
That's some serious airflow. I'm only pulling 1700 hz.
Old Oct 1, 2005 | 01:03 AM
joeymia's Avatar
Check this log out from earlier in the day. I was still running a little rich and less timing than when I went out tonight. I overwrote the log from tonight by mistake I can't wait till the new release of MPS logger.
Code:
RPM	PSI	MAF	TPS	Load	Knock	AFR	Inj	Timing	Mod MAF
3486	7.2	792	41	10	0	12.1	33.1	13.2	776
3572	8.6	950	55	20	0	12	40	10.1	1082
3615	10.4	1054	55	20	0	11.8	49.6	9.9	1136
3720	12.6	1190	71	30	0	10.4	57.3	8.7	1086
3796	14.9	1329	82	40	0	10.4	62.3	7.7	1219
3871	17.3	1436	100	50	0	10.5	65.1	6.8	1543
3949	19.1	1436	100	60	0	10.6	66.8	6.6	1479
4050	20.5	1533	100	70	0	10.6	68.9	7.1	1700
4145	21.3	1524	100	70	0	10.5	69.4	7.5	1388
4230	21.5	1567	100	80	0	10.7	69.6	8.8	1453
4334	21.5	1524	100	80	0	10.7	70.6	8.8	1677
4403	21.5	1607	100	80	0	10.7	71.2	8.9	1700
4528	21.5	1587	100	80	0	10.8	72.5	9.1	1785
4591	21.5	1661	100	90	0	10.6	72.8	10.2	1592
4668	21.3	1689	100	90	0	10.6	74.1	10.5	1602
4796	21.3	1683	100	90	0	10.6	75.2	10.8	1824
4873	21.2	1694	100	90	0	10.7	75.9	11	1748
4990	21	1779	100	100	0	10.7	74.3	12.4	1736
5050	20.8	1779	100	100	0	10.7	75.2	12.7	1824
5128	20.7	1785	100	100	0	10.9	77.2	12.9	1811
5216	20.5	1792	100	100	0	10.9	77.9	13.2	1811
5316	20.3	1845	100	100	0	10.9	78.3	13.4	1748
5411	20.2	1893	100	100	0	10.9	81	13.7	1798
5482	20.2	1915	100	100	0	10.7	82.3	14	1798
5574	20	1923	100	100	0	10.7	81.6	14.1	1824
5649	19.8	1915	100	100	0	10.7	82.5	14.4	1865
5737	19.6	1960	100	100	0	10.6	82.7	14.6	1824
5807	19.5	1937	100	100	0	10.6	83.7	14.8	1838
5868	19.3	1960	100	100	0	10.6	84.5	14.9	1879
5952	19.1	2000	100	100	0	10.5	84	15.2	1893
6038	19	2000	100	100	0	10.6	85.9	15.4	1865
6116	18.8	2016	100	100	0	10.6	84.8	15.7	1865
6184	18.6	2040	100	100	0	10.6	85.7	15.8	1923
6265	18.5	2057	100	100	0	10.6	86.1	16.1	1811
6337	18.1	2057	100	100	0	10.5	86.3	16.3	1893
6397	18	2083	100	100	0	10.6	84.8	16.5	1893
6459	17.8	2092	100	100	0	10.9	84.6	16.8	1908
6523	17.6	2092	100	100	0	10.9	83.9	16.9	1908
6613	17.5	2083	100	100	0	10.9	83.5	17.1	1824
6666	17.3	2118	100	100	0	10.9	84.6	17.3	1865
6720	17.1	2092	100	100	0	10.9	83.9	17.5	1923
6802	17	2083	100	100	0	10.9	85.3	17.7	1923
6858	16.8	2092	100	100	0	10.9	84.1	17.8	1748
6915	16.6	2092	100	100	0	11	84.9	18	1811
6973	16.5	2100	100	100	0	10.9	83.9	18.1	1923
7002	16.3	2109	100	100	0	10.9	84.3	18.3	1923
7077	16.1	2100	100	100	0	10.9	83.9	18.5	1865
Old Oct 1, 2005 | 01:07 AM
joeymia's Avatar
I was tring to get over 20 degress of timing by redline but I get knock. I am still using the stock plugs and ignition. Do you think getting one step colder plugs and the a Bushur coil-on plug with a MSD DIS-2 would help?
Old Oct 1, 2005 | 01:57 AM
What's wrong with the mps logger? the only problem i found was that the ecu timing wasn't appended in the evo log. So i just selected the sti utec option and i got my ecu timing appended. You run a lot more timing than i do in the 5k range. I always get knock around there. Here's a log. As for your timing, i can't really give much advice on that without getting on a dyno. If she doesn't knock, keep going i guess. If i encounter knock, i back off a few tenths of a degree around the area it knocked. Had a lot of trouble keeping the car to travel the same path through the map. It kept travelling to higher load sites each pull.
Rpm Boost Maf Tps Load Knock AFR INJ Timing Fuel Boost Mod Maf
3343 27.4 829 100 10 0 11.5 37.3 8.9 10.3 ECU. 957
3457 27.6 915 100 20 0 11.2 40.4 8.7 10.8 ECU. 788
3627 27.6 978 100 20 0 11.1 47.8 8.5 8 ECU. 1173
3711 27.6 990 100 30 0 10.9 50 8.5 6.5 ECU. 968
3858 27.6 972 100 40 0 10.9 47.1 8.9 3.5 ECU. 1179
4025 27.6 1050 100 40 0 11.2 48.1 9.5 2.9 ECU. 1141
4182 27.6 1103 100 40 0 11.3 52.2 9.8 2.6 ECU. 1162
4262 27.6 1126 100 40 0 11.3 53.1 10 3.6 ECU. 1190
4391 27.6 1170 100 50 0 11.3 54.3 10 4.3 ECU. 1184
4553 27.6 1196 100 50 0 11.1 57.6 10 3.8 ECU. 1219
4681 27.6 1250 100 50 0 10.9 58 10 3.3 ECU. 1231
4866 27.6 1272 100 50 0 11 56.8 10.3 1.9 ECU. 1315
4938 27.4 1302 100 60 0 11.3 60.6 10.9 4.5 ECU. 1373
5081 27.4 1340 100 60 0 11.2 59.4 11 3 ECU. 1358
5224 27.4 1366 100 60 0 11.5 60.2 11 -1.8 ECU. 1344
5359 27.4 1428 100 70 0 11.7 66.9 12 6.5 ECU. 1470
5482 27.6 1483 100 70 0 11.3 70.7 12 8 ECU. 1524
5592 27.6 1515 100 70 0 10.9 72.3 12.4 6.8 ECU. 1592
5787 27.6 1552 100 80 0 11 70.5 13 2 ECU. 1602
5910 27.4 1577 100 80 0 11.5 71.7 13.6 4.1 ECU. 1562
Don't pay attention much to the afr. I'm planning to do another fuel map from scratch.
Old Oct 1, 2005 | 05:04 AM
WarmPepsi's Avatar
joey, what gear are you logging in, 3rd?
i only ask because after seeing philip's logs, your load sites are at 100 like instantly. You're at 100 load below 5000, whereas phil hasn't hit 100, and i don't hit it at 7k @ 18 psi.
Whats the reason for that?
