Replacing The EVO MAS
Basically, you wire up your GM MAF in place of your Mitsubishi MAF, set a jumper on the ECU+ device, tell the software what you are doing...and then you're ready to roll. I've actually got TWO MAF's on my car at this very moment, a GM one and a Mitsubishi one, in series. We've switched between them with no noticable difference. It works!
--Dan
Mach V
MachEVO.com
--Dan
Mach V
MachEVO.com
Note, however, that you may have to re-tweak your fuel mapping, especially if you use the GM sensor in "blow through" configuration (that is, after the turbo). Our baseline measurements for the GM sensor were made with the GM MAF in the stock location. Your GM MAF may vary, so do plan to do fuel tuning accordingly.
--Dan
Mach V
MachEVO.com
--Dan
Mach V
MachEVO.com
Originally Posted by Stevdalpiaz
Wait a second, your Dan, I work next door to you, your with the special ed - I mean ops, right?.
When will you be back in town?
--Dan
Mach V
MachEVO.com
A friend of mine runs that set up on his 1st gen Talon.
LMFAO... used to work over in Spec Ops. Not any more. I'm actually TDY right now.
Who's your frined that runs it ..ROB?
ANd who is this ???
Dan
Actually a new product is in for the Evo. Check out http://www.maftpro.com/ with this you are able to run speed density and get rid of a MAF all together.
yeah thats what i was planning on doing. i know on dsm's thats where it is run most of the time wich allows for a vta bov, and a blowthru setup to the turbo. yeah if you could post pics up on how to wire that in i would also appreciate it
Originally Posted by Ev0ikon
Dan: Could you please post some pictures of your MAF setup?
Is it possible to set the 3" GM MAF just after the BOV/Recirc valve?
TIA
TIA
Yes, you could certainly put the MAF in the intercooler pipe after the BOV. Lots of DSM guys do it this way. Note that the MAF may respond differently in this mode (since you have much higher denstiy air under load), so you'll probably need to recalibrate your fuel settings.
--Dan
Mach V
MachEVO.com
Originally Posted by forum04pl
yeah thats what i figured, but i was wondering more about how to wire in the gm maf
Tom
yeah i just read through the manual on the wiring section today, i had no idea it was in there. i also learned alot of new stuff from it... seems quite easy i should be done with mine next week.
