My dynosheet with ECU PLUS
Originally Posted by forum04pl
i just got his map onto my computer but i need to plug it into my car to pull up a screenshot of it, ill try to get it to you tomorrow
I think I was talking to you at NE Dragway a couple of weeks ago... did you have the dynoflashed ECU that was messed up? I think you were trapping like 106 or 107....
yeah that was me unfortunatly, i am now running a ecu+ setup and it runs alot stronger. however i ran into some turbo issues (aftermarket) so the car hasnt been run on ecu+ and stock turbo yet.
pierre FYI that dyno does not read LOW especially on SAE correction, i think the difference between my car from sae to standard was about 10 whp on that dyno
go to KTR if you think that reads low, youd be looking at 280 maybe.
actually it reads slightly lower than a dynojet wich is what most people base their numbers off of on the site. so for him to say that it is a low reading dyno is a true statement. i think that someone is just mad that they are going to get put on now... hahaha
Nice! Can't wait to replace the SAFC with ECU+ this weekend and tune it. I had a reflash too but flashed back to stock due to problem with timing too high when tuned with the SAFC with the new turbo.
Thanks! I need that. Last time I used previous version of ECU+ and got P0300 which maybe because of the flash.
good luck, i have a feeling that you will see great results with the ecu+
Originally Posted by AutobonEvo
This is my dyno sheet i made 333.3 hp but he sent me my pull for 327.9 by accident. By the way this dyno reads low. The the dotted lines are what i put down with dynoflash and solid is what i but down after it was tuned on ecu plus. My mods are ECU+, 272 cams, turboback, MBC, and a intake.
ENJOY
BCcamevo.JPG Description: Filesize: 333.34 KB Viewed: 115 Time(s)
yeah i believe that he was running 22psi peak and tapering off to 19-20
also read the graph 24 psi is what jon inputed, just like precision said more boost = more power
finally pierre can put me on, took ya long enough jk
but remember im waiting for a 12.79@108.1 or better timeslip before any bs is throwni guess i need to actually break my ghetto modding budget now to hang with these cammed evos
if all else fails ill trade cars with derek for the night
Originally Posted by 12secondwrx
jons dyno reads a little high for torque then most other people that have run on different dynos within the same day, its all in the calibration. Id say the numbers are right on dynojet + a little torque ESPECIALLY IN SAE calibration, im sure you dont know the difference between the two anyways
in regards to pierre finally being able to put you on, if i remember correctly hes put you on before now its just going to be alot easier. oh and a cammed evo timeslip with a good tune with throw alot quicker of a time that a 12.79 @108, if you would like a copy of one i can send you quite a few...
oh yeah did i mention that even if derek did let you take his car you would completly missing the point of an evo being able to put your car on. but either way ill run you in dereks car.... oh and ill give you a two car length head start.
now when you show me a quicker timeslip than a 12.4 @112 then maybe you can talk to me about all of these technical DIFFERENCES (yes i like using caps lock to point stuff out just like you) that you THINK you know about. until then happy modding and stop trying to start **** in a forum where you dont even own one of the cars.
