Engine managment....hmmmm
Old Oct 27, 2005 | 10:16 AM
S2Kstephen's Avatar
Well, I recently purchased my HKS 280 cams, HKS cam gears, and ARP headstuds.
--I'm wondering if a simple mail-in Dynoflash would be suffice tuning for this setup?
--Would it be more advantageous to do a TurboTrix dyno tune instead?
--Do I need to upgrade headgasket, timing belt, etc...?
--Would I need a SAFC along with either a mail-in flash, or a piggyback?
Right now, I have the following:
HKS RS intake
Walbro 255 pump
RsR downpipe/cat delete
Agency Power Ti exhaust
Hallman MBC
Also, I'm planning on a GT30r kit in the Spring, so I'll probably be doing some headwork before then, to truely take advantage of any xtra RPM's I can get from th 280's.
Any suggestions/advice?
Old Oct 28, 2005 | 12:18 PM
isaac@vishnu's Avatar
I would take your car to Turbotrix and get it tuned. It'll run smoother, safer, and faster. You don't need a new timing belt or head gasket. The stock one is just fine. We run almost all our cars with stock timing belt and head gasket with this kind of set up. However if your on more of a budget a flash would work as well. When you go with your turbo upgrade in the future you may want to look into engine management.
KFK
Old Oct 30, 2005 | 08:03 PM
DynoFlash's Avatar
HKS RS intake
Walbro 255 pump
Hallman MBC
i have good mail in base flashes for the HKS intake - that intake is very consistant and uniform
Of course custom tuning will always be the preferred path but a ase flash works well for those on a budget or who are planning more mods soon
bojassem
16
Feb 19, 2010 07:18 AM
dkstas
May 8, 2008 03:22 PM
silvrevo
16
Dec 12, 2003 01:21 PM
